Electric fuel pump conversion
#121
No CEL, but I got an idea…. If the HPOP reservoir isn't all of the way full could that cause problems or trip a CEL. I took a hose off it to get the fuel lines in and didn't see it leaking and then in the morning I got a nice puddle on the ground. I heard if the HPOP is low ur truck won't start. Idk. I could slightly hear the turbo, but it should be LOUD. HHHMMMMMM??????
#122
Got a boost and EGT gauge coming. I am goin to clean up the plugs on the hpop and unplug the map sensor while it is running. Read a guy had the same issue and he unhooked the map sensor and she ran like a champ. IDK. With WOT my fuel psi don't drop at all.
Read this
http://www.powerstroke.org/forum/99-...eration-2.html
Read this
#123
Yes, if your HPOP reservoir oil level is low, the engine won't start. The injectors are activated by oil pressure from the HPOP.
#124
#125
#126
#127
I changed the banjo bolt to a y block and run 1/4 inch flex lines to the heads in the rear. Same 1/4 inch flex lines in the front going to the regulator.
I copied this setup basically.
https://www.ford-trucks.com/forums/1...-compelte.html
#128
Question then.. Supply 3/8 (-6an) to electric pump
Then can be 3/8 to Y connector .. Then hard lines (change out to $$ tubing.. Then Y to each head injector bank?? Correct?? What is the connector at the injector bank?? Can it be changed.. Take it it is hard line fitting.. I am coming from a common rail cummins ..
#131
#133
#134
HappeetxnR.N.
07-31-2007 09:27 PM
timmosazz
01-22-2006 09:53 PM
StevensPoint
07-19-2005 07:35 PM
