Upgrade to Heated Mirrors - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-02-2014, 10:25 PM
SD Dually's Avatar
SD Dually SD Dually is offline
SD Dually is starting off with a positive reputation.
Ok, from what I understand the heated mirrors CAN be hooked up to a switch so you can manually turn them on and off when needed, correct ? Would this apply to the newer style mirrors too ?
I'm thinking of ordering a set from 1A Auto, cut off the factory connection plug and wire up what I need manually since my truck does not have any power mirror wiring in the door.
As for hooking up the running lights and turn signals on these mirrors, it has dawned on me that the idea of tapping into the trucks running and turn signal wiring might be possibility due to the fact of the trailer plug might be on that wiring system as well, if this is the case then I don't see how the BCM can monitor this channel (or group of channels) since there is no way that Ford and/or the BCM will know exactly how many lights will be plugged into that circuit, as different trailers have different amount of lights.
Am I correct here, or is all this still a no go for me?
SD Dually
Old 02-04-2014, 10:10 AM
SD Dually's Avatar
Just thought I would bump my question again. Any thoughts?
SD Dually
Old 02-04-2014, 01:14 PM
Blue Jay Blue Jay is offline
Blue Jay is starting off with a positive reputation.
Just put the heater circuit on a switch by it's self and turn them on when you want. On the lights would not think they would be much of a load to upset anything.
Mirror upgrade wiring ligito 1999 to 2016 Super Duty 5 08-02-2016 05:40 PM
2006 expedition wiring for heated mirrors mystang89 1997-2006 Expedition & Navigator 7 11-02-2015 02:30 PM
2008 - 2000 Mirror Harness Trevor.801 Excursion - King of SUVs 10 03-19-2015 11:05 PM
'07 side mirror upgrade Waff78 2004 - 2008 F150 3 02-06-2015 10:55 AM
upgrade TT mirrors rosco_p_coltrane Excursion - King of SUVs 4 08-13-2006 12:11 AM
Tags
04, 2002, 2011, change, duty, explorer, f150, ford, forum, heated, mirror, mirrors, sport, super, trac, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
