Best ball joint tool to use on 2006 F150 4x4 - Ford Truck Enthusiasts Forums
Old 09-28-2011, 11:43 AM
shuttlevalve shuttlevalve is offline
shuttlevalve is starting off with a positive reputation.
I need to change out my right axle shaft and need to pick up the best ball joint puller for the upper A-arm and not destroy the boot seal. I was thinking about the OTC 6297. not sure though. Hate to figure it out when i have spread all over the drive way.
Old 09-28-2011, 01:29 PM
BatteriesNotINCL's Avatar
BatteriesNotINCL BatteriesNotINCL is offline
BatteriesNotINCL is starting off with a positive reputation.
Do you mean to get it off the Spindle or do you need to replace the ball joint? The upper ball joint is one complete piece from the factory and can't be separated. O'Reilly's sells an upper control arm that you can replace the joint, but wasn't recommended by the manager at my local shop.
As to separate the joint from the spindle, you can use a standard "tuning fork" separator using a high grade axle grease will keep the boot from ripping.
Old 09-28-2011, 03:13 PM
I need to pop the upper a - arm loose to change out the axle shaft from what i understand from the haynes manual. I have a pickle/tuning fork but i have ripped a few grease boots with it in the past. Since the joint is not replacable and needs to have the whole arm replaced i really didnt want to mess it up.
Old 09-28-2011, 03:42 PM
TallEddie-1981 TallEddie-1981 is offline
TallEddie-1981 is starting off with a positive reputation.
You can use a hammer to get the threaded stud of the ball joint out of the knuckle. Just hit the knuckle where the stud goes though, and it should come out.
check out this video, skip to the 5 min mark to see how this process works.
How To Replace a Front Wheel Drive Axle - YouTube
OPINION?? Best ball joints for the price and where did you get them?? tssngs75 1999 to 2016 Super Duty 5 11-18-2014 05:24 PM
'02 Mountaineer Upper Front Balljoint/CA questions 93f250tn Explorer, Sport Trac, Mountaineer & Aviator 6 09-26-2012 08:06 AM
Which ball joints? boosteddsm 1987 - 1996 F150 & Larger F-Series Trucks 2 06-15-2011 10:44 PM
THE Best Greasable Ball Joints mq1shooter 1994.5 - 1997 7.3L Power Stroke Diesel 21 03-29-2011 08:28 PM
Best aftermarket ball joints and hub? KRDiesel 1999 to 2016 Super Duty 14 09-12-2009 03:22 AM
Tags
09, 2003, 2005, 2006, 4x4, ball, balljoint, f150, ford, joint, joints, remover, tool, truck, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
