1953 bed question
Old 09-27-2011, 11:52 PM
Layed Out 100's Avatar
Layed Out 100
Layed Out 100 is offline
1953 bed question
I have two beds now but both have problems, one is just beat up and rusty and the other is beat up and PO welded a sheet of steel across the back as a tailgate. I'm a long ways off from actualy putting a bed on my truck (gathering parts) but I have been searching for one on craigslist in the range of 1953-1956 and would like to know how many years this bed stayed the same style? Seams like I noticed them looking the same on 60s f100s too.
Also, I have heard somewhere that in 1957 ford raised the fenders 1'' higher........can anybody tell me if thats true?
Old 09-28-2011, 07:11 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
On the last sentence, that is what I got from Sy at MidFifty when I told her my Prior Owner had mismounted the right side fender 1in higher.
Only in 57.
as I understand it the bed front/walls are the same 53-72. (except for the one year bolt holes)
tailgate changed multiple times
fenders I think are also the same 53-72.
Sam
Old 09-28-2011, 06:53 PM
Layed Out 100
Thanks Sam, that is just what I needed to know. Now if I can find a 57 bed it would save me a lot of work.
Old 09-28-2011, 07:48 PM
Stephen67's Avatar
Stephen67
Stephen67 is offline
Yep. I think the fenders till 79 also work with a little hole changing. The beds between 73-79 are wider and taller, like the long beds.
Lots of people use them as trailers around here.
Old 09-28-2011, 09:10 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Why would you want a 57 bed for your 53? You really don't want the higher mounted fenders...for one thing they won't mount up correctly to your 53-56 running boards. I have a set of bed sides, 57-72, out in storage that are very servicable just no body wants them.
Old 09-28-2011, 10:38 PM
Layed Out 100
I'm bagging the truck and would like the extra 1'' of clearance above the rear wheels. just an option I have been thinking about. I could add 1'' to the bottom of the fenders at the running boards and dont think it would be too noticable.
Old 09-28-2011, 10:43 PM
Layed Out 100
Stephen, I wish lots of people around still used them as trailers.........I think everybody around here pulled them across the scales and sold their homemade trailers for scap!
Old 09-28-2011, 11:02 PM
carbs & chrome's Avatar
carbs & chrome
carbs & chrome is offline
never mind - previously stated.
Old 09-28-2011, 11:32 PM
CharlieLed's Avatar
CharlieLed
That would work...if you choose to go that direction you may want to consider buying a couple of rear fender patch panels and using them to extend the fenders enough to reach the running boards.
Old 09-29-2011, 07:09 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
my red truck has the one 57 bedside, and the wider fiberglass fenders.. I didn't notice any alignment problem at the running board..
I can tell the difference at the wheel well vs the tire behind it.
gotta get a new bedside..
Sam
Old 09-29-2011, 08:05 AM
CharlieLed's Avatar
CharlieLed
Sam
Sam, did your fenders come pre-drilled? It may have been that you aligned your fenders to the existing setup and drilled to match. If so then you shouldn't have any problems...the FG fenders have a fairly wide flange on them so you probably wouldn't even have noticed if they were an inch or so lower in the front.
Old 09-29-2011, 08:25 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
these are the wider 3in fg fenders, so not predrilled.
the PO mounted them. there is no spare flange space to lower (unfortunately)
Sam
Old 09-29-2011, 09:31 AM
CharlieLed's Avatar
CharlieLed
Sam
I guess I wasn't clear in my statement about the fender flange...it sounds like the PO aligned the front edge of the fenders with the running boards and then drilled the flanges on the fenders to match the holes in the bed. Had he opted to use pre-drilled fenders, ala OEM stock Ford steel fenders, then he would have surely had a problem with the running board mounting holes lining up.
Old 09-29-2011, 09:40 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
ah.. you were talking about the front alignment.. I was talking about the actual fender/bed bolt holes..
got it..
Sam
SinfulCycles
06-17-2019 01:08 PM
proford1
10-21-2009 10:11 PM
Dadsf-21952
01-02-2008 08:48 AM
1Digger
12-30-2006 06:29 PM
Showpanther
07-31-2006 10:26 PM
Quick Reply: 1953 bed question
