351M to 460 swap? - Ford Truck Enthusiasts Forums
351M to 460 swap?
Old 09-27-2011, 10:11 PM
vinf100 vinf100 is offline
vinf100 is starting off with a positive reputation.
351M to 460 swap?
I have a 79 Bronco with 351M C6 trans . Motor is stuck so i bought a 75 460 out of a motor home . Some of the threads i have read on swaps have seemed to run into alot of problems. Will the 460 bolt in without alot of hassle? Power steering ,a/c , should be same from the looks of things ,and my guess is to keep 460 flywheel ? headers and aluminum intake on 351m work on 460?
Old 09-28-2011, 01:35 AM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Quote:
PS and AC pump an compressor may work, but it's a fair bet you need the brackets from the 460.
Keep the 460 flexplate.
Headers and intake will not work, not even close. The bore spacing is quite a bit wider on the 460. 351m is the same as SBF.
You will probably need a bigger radiator also.
One of my friends did this swap and was pretty happy with it, but it was nose heavy, especially with a winch, and it over heated unless moving.
He had a shop do it, so I can't tell you many more details, but search the swap via google and you'll find dozens of hits.
Old 09-28-2011, 11:28 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
use the 460 motor complete as you can. save and reuse the stock manifolds for the time being and use those funds for some L&L product mounts and such.
i would run at least a 3core radiator but the one you have may be fine just be prepared to swap it out if the 460 doesnt cool enough.
a 351m is not the same as a sbf and infact the 351m/400 intake is the widest of the bunch and much wider then the 460 intake.
Old 09-28-2011, 03:23 PM
"a 351m is not the same as a sbf and infact the 351m/400 intake is the widest of the bunch and much wider then the 460 intake"
True, but the bore spacing is the same which is the primary reason the headers would not work.
Old 09-28-2011, 04:53 PM
ok now im following you
Old 10-01-2011, 10:50 PM
Bronco308 Bronco308 is offline
Bronco308 is starting off with a positive reputation.
i am pretty sure the 460 will bolt up to ur existing transmission; not so if the 351 is a Windsor, like mine. from what pretty sure kemicalburns is correct, go with the 3-core radiator. here is a link from another site on this swap, not an exact swap, but a 460 into a bronco. Installing a 460 -- The Right Way!
Old 10-02-2011, 10:28 AM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
The modified block has the big block pattern bellhousing. He'll be fine with that.
351m to 460 Cgerman Engine Swaps 5 05-26-2016 12:52 PM
'77 F250 460 EFI swap Ordnance 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-12-2014 09:25 AM
79 351m swap with 84 460 Kevin Thayer 1973 - 1979 F-100 & Larger F-Series Trucks 17 01-23-2014 12:16 PM
351M to 460 a direct swap? pumpdriver20 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-29-2013 11:21 PM
351M to 460 motor swap 1979 F 250 project 1973 - 1979 F-100 & Larger F-Series Trucks 23 01-27-2013 06:17 PM
Tags
351, 351m, 460, bronco, close, clutch, flexplate, fuel, intake, power, pump, stage, steering, swap, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
