Intake Plenum Inserts......BY RIFFRAFF OF COURSE!!!
I've had them for awhile, was doing a little turbo work and put them in. What a great product and a great mod! My intake tubes were coned in from previous clamping, took the inserts and they just tapped in slick as snot! NOW I can clamp as hard as I wantoo within reason.
If you have the intake off then the holes should be covered or a rag stuffed in the hole. If it was me I would just leave the screens in. There not hurting anything and if you can tell a diff with them removed say on a dyno then it might be a good mod. But its up to you.
I disagree, drop a bolt in the intakes without those screens there and tell me whether or not it hurts. Cheap insurance if you ask me.
Standard operation for me is to stuff both with rags when the intake Y is removed... If you drop a bolt down there, you should be hit with a hammer...
Originally Posted by rat49f6
I know of a truck that sucked one of those screens into a valve on cylinder number 5 after it some how broke the welds
I've never seen that, but I have seen them pushed down inside the intake.
I just dont like anything that is in the way of air getting into my motor.
