Block sanding - Ford Truck Enthusiasts Forums
Block sanding
Old 09-27-2011, 08:04 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Block sanding
Just curious as to how many times you have block sanded before you decided enough is enough. I think I'm on my last round. No, I really am on my last go around. After all it's not going to be a trailer queen. I think I can live with the imperfections, especially after it's in final paint,lol. I sprayed 3 more coats of high build today and only a few flies in the primer Oh ya, my back and shoulder in sore.
Old 09-27-2011, 08:22 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Once - Thats not how many time I've block sanded per paint job - Thats how many times I've block sanded period = I that goes back to my Model cars days as a teen.
Old 09-27-2011, 10:05 PM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
Kinda like asking how many times have you gone down a road...you do it til you get to where you want to be. One thing that I have found is that there are many ways to "block sand"...in the old days I spent hours with a bucket, a block, and some 240/320wet-or-dry paper. These days I use 100 grit dry paper on a LARGE board (at least for large flat surfaces) and I get the primered surface flat long before I worry about removing scratches. Once the surface is flat, I spray another coat of primer and lightly block it with some 400 and I am good to go. Life is a lot easier now.
Old 09-27-2011, 10:11 PM
Stephen67's Avatar
Stephen67 Stephen67 is offline
Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.
I've had spots take one time and magically be perfect, and I've had spots take several months (daily) and a couple gallons to fix.
Though I agree, the longer the board the better. Long as you can in the area. A quick mist of paint before sanding also helps to show any high/low spots easier ( remember it all has to be sanded off before really painting)
Old 09-27-2011, 10:38 PM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
Like STEPHEN67 said a mist of black will show you any low spots. Thats the way i have seen it done.
Old 09-27-2011, 11:23 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I usually prime and block twice.....I try to get the body work as straight as possible, so I don't have to use (waste) so much primer. Doesn't always work out that way....
Old 09-28-2011, 04:17 AM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
A long board is the way to go and then guide coats when you feel you are getting close to the end, and then again just to make sure its perfect. But its all worth it in the end, just takes FOREVER LOL John
Old 09-28-2011, 09:23 AM
Posting Legend
Just complaining that's all,lol
I have been using long blocks and guide coat. I started this thread just to to find out to what time frame some of you put into their trucks. I keep saying that I just want to get it into final paint and then notice another spot that I should try to improve upon. Think I'll take Charlieled's lead and say I've come to the end of the road.
Old 09-28-2011, 04:57 PM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
Much rather block sand than wrench. It is more fun. LOl
Old 09-28-2011, 05:27 PM
4tl8ford's Avatar
Quote:
I'll remember that
Old 09-28-2011, 05:30 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
I'd rather have a prostrate exam.
Old 09-28-2011, 05:58 PM
ben73058's Avatar
ben73058 ben73058 is online now
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
I like the dents. If we all wanted trucks with no dents they sell them at the Ford dealerships brand new all day long. I don't want to have to worry about using the truck & driving it around to places where trucks naturally like to go - mud, dust, gravel, snow, etc. I know it might be crazy but I left dents on purpose in my paint - I feel like the truck earned those dents - badges of honor wear them proudly. Just my opinion - one or two passes with the sander & on to the paint.
Ben in Austin
Old 09-28-2011, 07:13 PM
Posting Legend
Quote:
Ben in Austin
I hear ya but haven't figured a way to go back in time to buy a new 56, all they have is those square things with no personality
Old 09-28-2011, 07:23 PM
Quote:
Originally Posted by 4tl8ford View Post
I'll remember that
Remind me too!! LOL
Old 09-28-2011, 08:34 PM
larryb346 larryb346 is offline
larryb346 has a good reputation on FTE.larryb346 has a good reputation on FTE.
You block sand it till it's right and only you can decide when that is.
Cutting (Sanding) and Buffing COMPLIT1107 Paint & Bodywork 2 05-02-2010 09:16 AM
My truck in the sand dunes???? John311t 1999 - 2003 7.3L Power Stroke Diesel 34 07-31-2007 01:49 PM
sanding, painting, sanding, now what? evilhorde Paint & Bodywork 4 04-07-2005 10:59 PM
2003 Ranger with SAND in the coolant system ploe 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 10 09-16-2004 10:26 PM
Wet Sanding Syzle Paint & Bodywork 13 07-02-2002 08:45 PM
Tags
1956, 56, block, f1, f100, ford, prime, sand, sanding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
