You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 08 f350 6.4 , my question is what signs or symptons would I encounter if my dpf was full or clogged ? Last regen it was making what appears to be white/grayish color smoke. Would it also affect mileage ?,and i'm not talking about the re-gen . With the current re-call from Ford in regards to the computer flash, it will only tell you when it goes into regen. but never when finnished unlike when i first recieved the truck.
try a 3000 rpm runup and look for a black cloud.
you dont say were your are or what the current weather is but it sounds more like a possible charge air cooler issue
__________________
Former Ford Senior master tech, gas and diesel.1992-2012
ASE Master Tech, L1 certified.
2006 f250 cc swb fx4 6.0
mods arp,egr delete, tuned, 91 gallon RDS fuel tank.
If you notice when it goes into Cleaning you can check the statrus by pressing the middle button on the information screen and then the top button. It will cycle through some system checks and then say "CLEANING EXHAUST FILTER". Of course when it's done cleaning it won't say that anymore, it will just do the system checks. Also, if you will watch the Average MPG screen as you drive you will notice it drop a couple tenths when the cleaning begins. I found seeing that was easier than seeing the CLEANING EXHAUST FILTER notice flash on for 3 seconds or whatever it is.
__________________ 2008 F350 DRW Lariat/ 4.30 Diff/Titan 60 Gal fuel tank/and just a little truck bling. Towing a 17,000 lb Mobile Suites all over the country.
I was under the impression "some" white/gray smoke during regen was normal? My 2010 has smoked for approx. 30sec to 1 min at the begining of the regen process since it was new. No codes....No making oil....etc.....etc....
It is possible depending upon how cold your exhaust system is and the ambient temps outside.
My truck resides in CT. the good ol TAX STATE. Anyway the truck has just over 30,000 miles and hours was around 1500+. Yes i have noticed the fuel suck down when it its regen. My truck has 3/73 gearing ,auto trans, stock tires 18in, new recently thanks to Continental and NO new contis now. i am equiped w/ Banks 6gun system but I am really itching towards a DPF delete an tuner someday . And i just went past Ford warranty so i am past 5 yr. 30,000 mile go figure. Radiator O ring issue had just happended now repaired by dealer.
an other regen indicator is cruise around 55 and reset your fuel mileage if it jumps to 7-12 then starts to round to 10 then it's in a regen, and if its not it should jump to 14-27 mpg then round off to 17
or when you accelerate it will be very reluctant to boost above 20psi instead of 30 so easily when it isn't doing a regen.
typically "signs" of a bad DPF are black tailpipes. these engines should not produce soot/smoke and technically shouldnt have any soot in the tailpipes either so long as you are getting it hot enough to complete regular regens.
With that said, I have already had a DPF replaced but after 5,000 miles my pipes turned black again. 1 dealer told me its normal, another said I dont drive the truck often enough (even though I work it hard when I do drive it), and the most recent dealer told me its due to poor fuel quality and I should use Ford's cetane booster. When I said I use DK with every tank their only reply was "but thats not Fords brand".
Its frustrating because I think their answers are false but if the dealer wont admit theres a problem, then there isnt a problem. same way if a referee doesnt call a facemask penalty, there wasnt a facemask. End of story.
__________________
2008 F350 CC 4x4
Harley Davidson 6.4 PSD Auto
Job #3 build, 2" leveling kit, rear air bags, smoked cab lights and mirror lenses
