2005 F150 4x4 transfer case problem - Ford Truck Enthusiasts Forums
Old 09-27-2011, 04:20 PM
BARRY HAMPTON BARRY HAMPTON is offline
BARRY HAMPTON is starting off with a positive reputation.
My transfer case will only pull vacuum to the hubs when floor shifter is in between 4 low and 4 high. as soon as the dash light comes on for low or high it looses vacuum. Is there a switch that tells it to pull vacuum? Does anyone out there have a good breakdown of the transfer case?
Old 09-27-2011, 04:58 PM
Jake_f16's Avatar
Jake_f16 Jake_f16 is offline
Jake_f16 is starting off with a positive reputation.
I don't think I understand what you are saying....When you put your truck in 4 wheel drive the hubs should loose vacuum to allow the hubs to lock into place. When you put it back in 2 wheel drive the hubs should have vacuum to pull the hubs back and disangauge the hubs. In 2 wheel drive your hubs will always have vacuum.
Old 09-28-2011, 07:20 AM
f150 4x4 transfer case problem
My understanding is that vacuum engages the hubs. I could be wroong, hopefully someone out there has gone through this before.
Old 09-28-2011, 09:04 AM
Jake_f16's Avatar
Barry
The vacuum keeps your hubs disengaged until you put the truck in 4 wheeldrive then the vacuum releases the hubs and allows them to engage.
Old 09-28-2011, 09:12 AM
So in theory with the engine off and vacuum depleated if I jack the front tires off the ground the huds sould be locked in?
Old 09-28-2011, 09:13 AM
That would mean in a pinch I could pull the vacuum lines off the hubs and I would have 4 wheel drive?
Old 10-07-2011, 07:32 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
Short answer= yes.
Here's the best trouble shooting info for the 4x4 vacuum system;
http://www.ford-trucks.com/forums/83...then-some.html
Low range 2 wheel drive lkbenson 6.7L Power Stroke Diesel 4 06-05-2015 10:52 AM
2000 Ex/F250 4x4 issue Drewcifer101 1999 to 2016 Super Duty 0 05-25-2015 08:30 PM
F150 5.4L 4WD WON'T ENGAGE DENNY1968 1997 - 2003 F150 4 09-19-2010 09:34 AM
**UPDATE** Pulse Vacuum Hubs and vacuum solenoid? John TN Ranger & B-Series 2 12-01-2009 04:05 PM
99 f-250 4x4 vunger1 Southern Region 1 11-07-2008 10:05 AM
Tags
05, 2004, 2005, 4x4, case, diagram, f150, ford, hubs, motor, problems, recalls, shifter, transfer, transfercase
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
