Removing the front bumper. - Ford Truck Enthusiasts Forums
Old 09-27-2011, 12:48 PM
Corrupt Silence's Avatar
Corrupt Silence Corrupt Silence is offline
Corrupt Silence is starting off with a positive reputation.
Question Removing the front bumper.
I was going to originally cut back the frame horns and pull the front bumper closer in to the front valance. After much thought and checking out many, many trucks at local shows, I have decided to remove the front bumper all together. Does anyone have a solid dimension that you know works? How far from the front of the frame horn should I go back to cut the horns and allow clearance for the front valance? After cutting the horns back, did anyone weld or bolt a cross member at the front of the new frame locations to act as a bumper behind the valance in the possibility of an accident? I'm down to bare frame right now, and am certain this is the direction I'd like to go. Any help in doing this would be very much appreciated.
Old 09-27-2011, 05:17 PM
Holmsey's Avatar
Holmsey Holmsey is offline
Holmsey is starting off with a positive reputation.
I put my front valance back on and marked it, then cut it, that's all. But a crossmember as a hidden bumper would be a good idea.
Old 09-27-2011, 06:02 PM
Thanks...
I am literally bare frame right now. I suppose it's one of the easier things to get too. I could just wait until I start putting body work on I suppose...
Old 09-27-2011, 08:05 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
I'm putting fog lights in the two holes where the frame poked through.
Ben in Austin
Old 09-27-2011, 09:20 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
The heavy ribbed bumper on '51-'52 was touted as strengthening the frame substantially. I noticed a difference when I got mine bolted up solidly. I don't see what a crossmember could hurt, especially with an IRS. They like rigid frames.
Old 09-27-2011, 10:24 PM
arrowheadfred's Avatar
arrowheadfred arrowheadfred is offline
arrowheadfred has a good reputation on FTE.arrowheadfred has a good reputation on FTE.
A cross brace is a good idea. I like the running light idea also. That will look good !!!! Maybe even cut a flat spot in the middle for a front tag. If ya did something like this and used a fliped down tag you could even weld a tow hook to the brace just in case you need to pull it.
Old 09-29-2011, 11:50 AM
Holmsey's Avatar
Yeah I would 2nd tow eye. Wish I had fitted one... well ya never know I may do over the winter and make a brace to ;o)... thanks for the ideas
Suck in that front bumper... Corrupt Silence 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 02-12-2011 01:24 PM
92 -96 F150 4x4 Factory body and bed "lifts" phoneman91 1987 - 1996 F150 & Larger F-Series Trucks 4 06-04-2010 04:11 AM
Front frame rail? learpilot 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-26-2009 07:15 PM
05,06,07 Front Bumper and Valance on 03 F350 Dually Tennesseepowerstroke 1999 to 2016 Super Duty 4 08-18-2007 11:53 AM
Tucking in 56' f100 front bumper. 56Fred 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2006 06:32 PM
Tags
1954, 1978, 1996, 2000, bumper, clip, f150, fog, ford, front, lights, remove, remve, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
