5R110W 2006 External Filter
No, that's not right.
The 5R110W (TorqShift) transmission was introduced in 2003. It had an external filter. Mid year 2008 the external filter was dropped and the internal filter was improved. The new internal filter is a better filter than the external filter was, and it filters 100% of the fluid. The external filtered either 10% or 1%, depending on whether the internal transmission thermostat was opened or closed.
You can retrofit the new internal filter to an older TorqShift, but you have to change the pan to match the new filter.
Mark, I have that tranny on my 06 F-53. I changed the filter, I went with this filter: http://www.filtranllc.com/home/docum...rap-030508.pdf
I thought I had read that the Ford filter was junk and it could easily clog up and block fluid flow to the cooler.
Your thoughts?
Your thoughts?
