PCV valve - Ford Truck Enthusiasts Forums
PCV valve
Old 09-27-2011, 11:29 AM
harley3348 harley3348 is offline
harley3348 is starting off with a positive reputation.
PCV valve
Does my 1991 F150 XLT 5.0 have a PCV valve. If yes, can someone point it out.
Thanks
Old 09-27-2011, 11:36 AM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Yes, it should. It is located on the rear of the passenger side valve cover. I have a pic in my "'92 Ol'e Blue" album if you need a pic of the location. If you are replacing it, be sure to spend the extra few dollars and get a Motocraft PCV valve as a replacement. Not an OEM equivalent. Your local Ford dealership has them for about $7 or 8 bucks. Hope this helps.
Old 09-27-2011, 11:38 AM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Quote:
Thanks
Yes, it does...
Passenger side valve pan cover, main back.....Simply pull it out, swap with the new one, and push it back into the grommet...
Old 09-27-2011, 11:40 AM
Thanks Wes for posting the diagram.
Old 09-27-2011, 11:44 AM
Quote:
Welcome...Actually, I'd just gotten that pic....lol
More added to my growing library of diagrams, doodads, etc...Need a diagram? hit me up....lol
Old 09-27-2011, 11:47 AM
PCV valve
Thanks Wes. Great picture. Would you also have a picture of the a/c componets on the same engine. I have what appears to be an a/c pressure switch located right by the oil filler cap. The switch is there with two wires coming out of the top that someone has cut. I am looking to reconnect them.
Thanks again,
Harley
Old 09-27-2011, 11:51 AM
Thanks again,
Harley
Ummm I'm not sure of what you're meaning...There is no A/C components ON the engine, except for the A/C compressor....
Lemme see what I can turn up though...
Old 09-27-2011, 11:56 AM
PCV valve
Wes,
I have a photo of it but when i have tried to send photos in the past i have trouble. I am not exactly a computer genius.
Old 09-27-2011, 12:02 PM
TheWhiteBeast TheWhiteBeast is offline
TheWhiteBeast is gaining momentum as a positive member of FTE.
Probably just the fuel injector test plug.
Old 09-27-2011, 12:42 PM
here is the pic you sent me......
Old 09-27-2011, 04:02 PM
ChristopherN ChristopherN is offline
ChristopherN is starting off with a positive reputation.
It's a bit of a pain to change out but, you need no tools to do it.
Old 09-27-2011, 04:09 PM
Quote:
Negatory....Ya need opposable thumbs!
Old 12-13-2015, 02:35 PM
Jack Schitt Jack Schitt is offline
Jack Schitt is starting off with a positive reputation.
1991 F-150, 5.0 V-8
My PCV valve is new all filters are new plenty of suck on the PVC valve and plenty of blow out of the other side (next to oil fill) however there is so much blow, it will blow a quart of oil in 75-100 highway miles out of the air filter intake therefore soaking the air and PCV filters, running down the inner fender. Help! Any suggestions?
Old 12-13-2015, 03:05 PM
joey2fords's Avatar
joey2fords joey2fords is offline
joey2fords is gaining momentum as a positive member of FTE.
time to test compression.
Old 12-13-2015, 04:31 PM
I completely agree on checking compression.
Also, are you using dino, synthetic blend, or Synthetic?
What's the maintenance history of the truck? Could be the oil passages in the head a clogged allowing for the puking into the air filter box.
PCV Valve? Redskins Escape & Escape Hybrid 21 08-14-2015 02:28 PM
pcv valve rugateer 1999 to 2016 Super Duty 1 11-18-2014 01:31 PM
PCV valve fordmaniac21 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-23-2008 12:41 PM
Pcv Valve on 88 f150 irishman200232 1987 - 1996 F150 & Larger F-Series Trucks 8 02-08-2004 07:26 AM
PCV valve location on a 5.8 restorit 1978 - 1996 Big Bronco 6 05-30-2002 07:54 AM
Tags
02, 1991, 2004, 46, 50, 91, cover, diagram, expedition, f150, ford, passenger, pcv, side, system, valve, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
