Confused with 7 pin trailer connector - Ford Truck Enthusiasts Forums
Old 09-27-2011, 10:08 AM
secolvin secolvin is offline
secolvin is starting off with a positive reputation.
I do not understand what is going on with my trucks 7 pin connector. I have tested each pin by the ohm meter with someone in the truck working brakes/blinkers. It does not make sense. I had to put a new connector on my horse trailer. The problem is, the wires broke inside the trailer's connector so I can't tell what went where. But the truck side is not helping me figure out what to do.
Question 1. Isn't there supposed to be a pin that shows 12V only when the brakes are applied? I would assume this goes to the trailers brakes. There is not a pin on the truck that gets hot with brakes applied.
Question 2. Isn't there supposed to be a pin that shows 12V when the lights are turned on truck? I would assume this goes to the marker/running lights on the trailer. There is not a pin that gets hot when lights are applied.
Question 3. Why would the truck have 2 pins that show 12V at all times? All wiring diagrams I have read online only show 1 pin with a always hot 12V.
Note - left turn, right turn, and brake lights work
Old 09-27-2011, 10:41 AM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
maybe this will help. if you have to use a batt to find what wire is what on the trailer.
no 12v on brakes would not work good. there is a 12v with the key on.
yse the 12v with lights is running lights
1 is the brake controller the other is the all time 12v.
Old 09-27-2011, 10:43 AM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Did you check the READ FIRST posts at the top of this FORUM??? There are wiring diagrams up there......http://www.ford-trucks.com/forums/59...0-13-10-a.html
Old 09-27-2011, 11:02 AM
truck not behaving per diagram
Here is what is how the truck connector is behaving.
1. Ground - correct
2. Brakes - incorrect, always 12V. Shouldn't this only be when brakes are applied?
3. Markers - incorrect. Does not show 12V when the truck lights are turned on. Shouldn't this be 12V with truck lights?
4. 12V Aux - correct
5. turn/brake - correct
6. turn/brake - correct
Could a relay or fuse on the truck be causing these symptoms?
Old 09-27-2011, 11:11 AM
dchamberlain's Avatar
dchamberlain dchamberlain is offline
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
2. Your brake controller may be putting 12V on the plug to detect trailer brakes. Once it sees a circuit it would cut that power. What kind of brake controller do you have?
3. Check your trailer tow parking light fuse.
Old 09-27-2011, 11:13 AM
BPofMD's Avatar
Posting Legend
2 and 3 reversed?
Old 09-28-2011, 04:30 PM
Fixed it. Miswired trailer plug had blown fuse on truck effecting pin 3. Corrected trailer plugs 2, 3, and 1. Good to go now. Not a single wire color on trailer followed conventional color schemes. Nightmare.
Old 09-28-2011, 05:00 PM
BPofMD's Avatar
Posting Legend
Never-ever go by color codes when two different manufacturers are concerned....ALWAYS go by applied voltages!
BTW....CONGRATS on figuring it out! Persistence always wins out!
first trailer hookup on the new truck - wiring issues contento Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 14 06-07-2014 08:16 AM
Factory Wire Harness Pin Out 728Winston Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 8 03-27-2014 06:12 AM
Reverse Sensor auto-cutoff robert_l_ross Excursion - King of SUVs 2 08-26-2012 01:56 AM
Wiring a Trailer Tow Battery jonesn4fun Electrical Systems/Wiring 1 10-24-2011 08:06 PM
Seemingly factory trailer wiring Question? Handegard 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 12-24-2009 02:26 AM
Tags
1997, 2008fordexpeditionlimitedtrailerconnectionisntwork ing, 73, conector, connector, diagram, diesel, ford, navigator, pin, plug, trailer, truck, wire, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
