Performance difference's between rear end ratios. - Ford Truck Enthusiasts Forums
Old 09-27-2011, 02:45 AM
640 CI Aluminum FORD 640 CI Aluminum FORD is offline
640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.640 CI Aluminum FORD has a great reputation on FTE.
I've been keeping up with the latest in 2011 F-150 road tests and all that stuff. Here recently I've noticed something that I found a little intriguing. Recently there have been two fairly major road tests and comparison's that a 2011 F-150 was involved in. The particular truck I want to you take notice of in the first test ''which only includes F-150s'' is the one with the 5.0L V8. In the second test the only F-150 that was there to compete was one with the 5.0L.
The thing I find interesting is that the 2011 F-150 5.0L that was tested by Truck Trend ran a 0-60 of 6.9 seconds. Keep in mind that it was a 4X4 Crew Cab with a 3.73 rear end.
Now the one tested by Pickuptrucks.com was a regular cab 2WD 5.0L with 3.55 rear end...And it ran the same 6.9 second 0-60 as the much heavier Crew Cab 4WD F-150 with the 3.73 rear end.
Considering the weight difference I would have expected the 4X4 F-150 to noticeably slower perhaps 1/2 a second or so to 60? But instead it runs nose to nose with the lighter 2WD model...Does making the jump from 3.55 to 3.73 really yield that much extra performance?
I personally own a 2011 F-150 FX4 Supercab with the 5.0L and 3.73, and I even test drove an XLT 5.0L Supercab with 3.55's before I made my purchase. To me my 3.73 equipped truck maybe feels a little more punchy off the line...But really any real world difference seems negligible. Let me know what your thougts on the subject are.
5.0-liter V-8 XLT SuperCrew 4x4 - 2011 Ford F-150 Comparison Test - Truck Trend
http://special-reports.pickuptrucks.com/2011-30k-
shootout.html
Here's the spec's for the trucks tested in the order I've placed the tests above this.
2011 Ford F-150 XLT SuperCrew 4X4
5.0L V8
3.73 Rear End
Curb Weight - 5640lbs
0-60 = 6.9 seconds
1/4 mile = 15.3 @ 93.30
2011 Ford F-150 XLT Regular Cab 2WD
5.0L V8
3.55 Rear End
Curb Weight - 5,110lbs
0-60 = 6.9 seconds
1/4 mile = 15.4 @93.31mph
(530lbs difference in curb weight)
''Note''
For some reason Pickuptrucks.com neglected to include the spec's for the trucks used in their test. So I had to look up the curb weight online for a Regular Cab 2WD 5.0L F-150. The numbers may not be exact to the F-150 used in their test...However they are very close.
What do you think? Why did the almost 600lb heavier F-150 run the same 0-60mph time and almost identical 1/4 mile time and trap speed? Could this be due to gearing alone? Did the Crew Cab just have a hot engine or in vice versa the Regular Cab had an underachiver engine?
I've never personally run my 5.0 Supercab FX4 in a 0-60 or 1/4 mile so I can't speak for myself...But I did however watch a factory stock 5.0L regular cab 2WD F-150 run a 14.5 1/4 mile @ 95mph (Speed Limiter) and that particular truck had a 3.73 rear end.
Old 09-27-2011, 06:46 AM
tseekins's Avatar
tseekins tseekins is online now
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Different trucks, different locations and different drivers.
One only needs to look at the super duty line-up to see what a powerful engine and a six speed transmission do to truck capability and fuel economy.
Old 09-27-2011, 07:33 AM
todd230's Avatar
todd230 todd230 is offline
todd230 is starting off with a positive reputation.
I'd believe it - gearing is a huge part of straight line acceleration. Think of timing 0-20 MPH from a stop in 1st gear vs starting in 2nd gear. It's about getting to and keeping the motor in it's power band. I would think the 5.0 would be more gear sensitive than the EB simply because of the power band - 5.0 makes peak torque and HP higher in the RPM range so that first to second gear time would probably account for a good chunk of ET not running in the ideal power band - then at the end of the run where wind resistance plays a larger part the 3.73 is also helping.
Old 09-28-2011, 05:49 AM
FORD FRED FORD FRED is offline
FORD FRED is gaining momentum as a positive member of FTE.
The super crew would have more weight on the back axle helping it to get traction and get out of the hole faster. Also if the 4x4 was engaged it would also help it to get out of the hole faster. Just my 2 cents worth.
Old 09-28-2011, 11:13 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
Gearing makes a huge difference in acceleration; I'm not sure why you're wanting to debate this so much...
Old 09-28-2011, 11:55 AM
shortride's Avatar
shortride shortride is offline
shortride is gaining momentum as a positive member of FTE.shortride is gaining momentum as a positive member of FTE.
One consideration is that these late model engines have the ability to adjust the ignition, valve timing and fuel control under different conditions. This could explain some of the performance characteristic differences.
Old 09-28-2011, 12:03 PM
Quote:
Originally Posted by shortride View Post
One consideration is that these late model engines have the ability to adjust the ignition and maybe valve timing and fuel control under different conditions. This could explain some of the performance characteristic differences.
The gearing explains it... Lower gears apply more torque at a lower speed to the rear wheels, which will provide more acceleration. Pair that with a heavier vehicle and the lower gears will attain similar acceleration to a lighter vehicle with taller gears, though at the cost of highway mileage and top speed.
Old 09-28-2011, 12:39 PM
shortride's Avatar
Quote:
Absolutely!
This is the only reason for my post.
Quote:
Supercharge 2005 F150 or buy new '15 vladdy805 2004 - 2008 F150 8 12-15-2015 09:58 PM
2012 5.0L vs 2011 Ecoboost (Drag Race video clips!) 640 CI Aluminum FORD 2009 - 2014 F150 68 04-17-2013 10:08 PM
1989 f150 and bronco curb weight Nally427 1987 - 1996 F150 & Larger F-Series Trucks 1 08-11-2012 11:37 PM
2011 towing MPG 3.7 or 5.0 Fred Smedley123 2009 - 2014 F150 20 07-10-2011 04:05 PM
Got to drive all the 2011 F-150 engines and this is my review! 640 CI Aluminum FORD 2009 - 2014 F150 38 01-18-2011 05:53 PM
Tags
060, 150, 2006, 2007, 4x4, axle, cab, differances, end, f150, ford, ratiodifferences, rear, roush, specs, supercrew, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
