Problems with Engine!? 1951 F1, 226 cui - Ford Truck Enthusiasts Forums
Old 09-27-2011, 01:20 AM
moidan moidan is offline
moidan is starting off with a positive reputation.
hi
i own a
1951 F1 Pickup
226 cui
GVWR: 4700 lbs
engine #: 7HA6050-C2
and i think i have a problem with the engine
What is wrong with the engine if fluid (i think fuel) comes out of the hose at the pic?
For what is this hose?
Many thanks in advance!
best regards from austria
passenger side under the intake manifold:
Old 09-27-2011, 07:23 AM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
What you have there is the precursor to the PCV valve. The pipe coming off the side cover is called a "road draft tube" which equalized the pressure inside the engine. For more info try this post:
http://www.ford-trucks.com/forums/10...-i6-226-a.html
Old 09-27-2011, 08:53 AM
bacagrizz,
thanks for the link!
I have read the linked post. Unfortunately I am still not clear what's wrong, if fluid comes out of the hose.
I hope you can explain that in more detail.
Following the diagram from the engine:
Old 09-27-2011, 11:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Is the "fluid" more than the amount of condensation you would expect on start-up? Is it an actual flow of water? If so, you have a cracked block and water jacket coolant is leaking into the valve chest. Is the fluid green like antifreeze? If it's a cracked block, it will leak out of there whether it's running or not.
If it's just a drip-drip-drip of clear water when running, you need to warm up the engine thoroughly to evaporate water in the crankcase, and probably change the oil.
Old 09-27-2011, 11:40 AM
On last sunday we had the following situation:
After a halt of about 6 weeks we have started the truck again.
Then, for about an hour, fluid (about 0,4 gal) came out of the hose. not in idle, only on accelerate. The liquid smelled like gasoline. Maybe mixed with some oil. But we are not really believe that even cooling liquid was present because in the radiator was nothing less Damn - I really have no idea what that is. It's also not possible that so much gasoline flows through the engine, right?
In the meantime, we drove about 150 miles with the truck without liquid coming from the hose. Only some smoke on the first 60 miles. Then this stopped also.
The engine is not getting hot and on the day after no oil or other liquids was on the floor.
Please forgive me my bad English.
Kind Regards,
Daniel
Old 09-27-2011, 11:55 AM
ALBUQ F-1's Avatar
postin' fool
Check the oil; does it smell like gas? I suspect your fuel pump diaphragm is ruptured and gas is getting into the crankcase. The fumes will condense in the valve chest. Needs to be fixed ASAP!
Old 09-27-2011, 01:53 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
ASAP = as soon as possible.. in case our Austrian memeber didn't know.
Old 09-27-2011, 01:56 PM
daniel
Old 09-27-2011, 06:14 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Indeed...ALBUQ F-1 is giving you good advice. If the fuel pump diaphram is broken, gasoline can go into the crankcase. Initially it will dilute the oil, but it will quickly evaporate and the fumes will go out of the road draft tube. If it was cool out and you were just warming up the engine, the fumes could condense and show up as a liquid. Later on when everything was warmed up it would just go out as a vapor. You probably would notice that your gas mileage is a little worse than normal. The oil level may also appear to be a little high.
And...welcome from California. Maybe you could send us another Austrian governor for our state!!
Dan
Old 09-27-2011, 07:09 PM
51PanelMan's Avatar
People of Kahlifoneeah!
Old 09-28-2011, 02:34 AM
Quote:
Dan
That will not be easy. The good politicians in our country are not easy to find because they occur very rarely. The most others are like our comedians: talk a lot nonsense, unfortunately is not for laughing
Oh, and we have to offer no more Hollywood stars to.
Daniel
Old 09-28-2011, 11:13 AM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is online now
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Quote:
Ilya ! I got it! LOL
Old 09-28-2011, 11:19 AM
51PanelMan's Avatar
My other two favorites are: "Who iz yoh dahdee and what dahs he dooh?" and "I'm a kop, you eedeeot!" Both are from the greatest movie of his career, Kindergarten Cop.
Distibutor ID jayboundless Ranchero & 1961 - 1967 Econoline 3 09-17-2015 06:04 PM
Fresh into the Ford Game! RustFreeBucket New Member Introductions 4 07-24-2014 04:21 PM
54 F100 AUTO Transmission wont backup mode101 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-22-2014 01:00 PM
How many cui does my engine have? Andy_F100 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 12-05-2012 08:28 AM
1951 F1: VIN & Chassis # and other infos for a rookie moidan 1948 - 1956 F1, F100 & Larger F-Series Trucks 33 09-28-2011 07:52 AM
Tags
1951, 226, 292, antifreeze, cyl, draft, engine, engines, f1, flathead, ford, fumes, gas, leak, pipe, unusual
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
