1968 ford f250 ignition stuff need help!!
Well pretty much I am wanting to convert to electronic ignition on my 68 f250 that has a 360 in it.. I recently had replaced the original distributor with a reman. Napa dizzy. And am now looking into getting a pertronix ignitor III electronic ignition unit and flamethrower III coil.. The problem is that the unit says it only works with a certain number of dizzys and napa ones are not one of them.. So my question is if I'm wanting to switch to electronic ignition will I need to buy a new dizzy or will my current one work with the pertronix system? (and does anyone have anything to say about pertronix units also..).
Thanks in advanced,
Corey m.
Thanks in advanced,
Corey m.
this is the ONLY way to go.... it uses the chevy cap coil and button, chevy from the base of the cap up and ford from there down, i put one on mine and just had to run 1 acc wire to the coil built in on the cap. do away with them PESKY POINTS and that Ford flop for a box on the fender and get one of these u will love it
http://cgi.ebay.com/ebaymotors/FORD-...item4cf9d18c74
Corey, Can't totally agree with Dale, The Petronix is an excellent upgrade from stock. I am not sure of the difference between II & III. I believe I am running a II in my truck.
You need not be concerned from where you purchased the dizzy. You will be buying for a 68 With a FE 360. That is about all that is required.
The Duraspark is also a very good upgrade.
John
John
John
John
If you don't mind me picking your brain a bit more I'm leaning towards the pertronix II upgrade with the Flamerthrower II coil. When you converted to the ignitor II Did you change the distributor also or where you able to keep your stock distributor? And what do you think about the product overal?
No you use the standard/stock distributor. Now should you have wear issues with your distributor and it needs changing you still will have to.
The Petronix replaces the points in the distributor.
The Petronix is a very good aftermarket ign system. The Duraspark is a Ford ign. system. Either is better than the original points system.
John
John
fromme87
01-21-2017 02:07 AM
66MercMan
01-29-2004 06:41 PM
fordeverpower
23
10-17-2003 02:53 PM
Dan-79F350
05-19-2000 12:52 PM
