Great Grandfathers 1950 f1
8R - 8 cyl
C - 1/2 ton
418226 - production number
High production number suggests that it is a 1950. Likely a very late 1950.
SP - Saint Paul, MN production plant
......That being said I am wondering alot about the origianl configuration of this truck. The first questions that come to mind are what size tires it would have had on it and how the bed was constructed. Did it have wood or was it a metal pan?
Thanks for any guidance.
More pics to come.
More pics to come.
As late as your truck was produced you could do either IMHO and be correct. Take a close look at your box sides and see if there are any tell-tale signs of a floor pan or spotwelds around the perimeter.
The metal pans used a wood subfloor that was made up of scrap wood. Mine had pieces that tapered as much as 2" from front to back. Ford didn't waste much....
That's ok, we don't really know what to call them either. It usually is just called an early style or raised panel box. : )
Be very careful with that tube that is on the passenger side. The one that goes into the heater. that tube is worth its weight in gold( not literally) if it is anything but complete rust dust. From the picture, it looks at least usable. that is the fresh air intake for the heater. There should be another part to all the way to above the pass. side headlight to a vent/screen in the grill. You are planning to take this back to as close to original as possible, so just trying to help out!
You got a lot done in a short amount of time!
Ford began requiring a fat yearly license fee in the 1990's to be able to use their name/part numbers. AFAIK, only Dennis Carpenter pays the fee.
Most of the obsolete parts sellers were forced to drop Ford from their business names, because they didn't want to pay the yearly fee.
This all came about because of cheap, poorly made Taiwanese sheet metal/body parts that began flooding the US in the 1980's. The makers/sellers were using Ford part numbers/applications.
FoMoCo's lawyers sued to force them to cease and desist, some did, some did not. Ford then began applying for patents on body parts, this didn't help much either.
FoMoCo's lawyers then went after the 100's of obsolete parts sellers that were using Ford in their business name, Ford part numbers in their catalogs.
One long time seller of Model A parts told FoMoCo to go to hell...soon regretted that remark.
When he set up at the Carlisle Swap Meet, a team of Ford lawyers and the polizei were waiting for him, confiscated his entire inventory!
Now you know why it's Classic Auto Parts, no longer Obsolete Ford Parts of OK
Tveter50: 1948/52 F1: The original tire size was 6.00-16, 6.50-16 was optional. These were 4 ply bias ply blackwall tires. Radials were not available, because...
Radial tires were invented by Michelin in the early 1950's.The first vehicle in the world to have radials as standard equipment was the 1955 FWD Citroen ID 19 (Michelin owned Citroen at that time).
The first US vehicle to have radials as standard equipment was the 1966 FWD Oldsmobile Toronado. GM discovered while conducting tests, that bias ply tires wore out within 7,000 miles.
Ford didn't offer radials until the 1970's and then, only as an option. White wall (w/wall) tires for trucks were not offered as an option until 1956.
1951/52: During the Korean War, w/wall tires were not available...period...for any new vehicle. Not even the high buck luxury cars like Cadillac/Packard/Lincoln/R-R/Bentley came with w/walls.
The bed floor was pine originally and was painted body color (not stained/varnished like you see on a gazillion 'restored' trucks today).
The wood came from Northern MI because...Ford owned the forests, the sawmills and the ships that transported the product to The Rouge.
Thanks for the advice about the air intake for the heater. We will be very careful. The hope is to have the truck back together by the middle of January. A family friend has a beautiful workshop and is looking to stay busy this fall and winter. It is amazing what you can do with an experienced hand helping and the right tools.
I am having trouble locating a replacement wiring harness for the truck. It will stay the 6v system. Any leads?
Any repro parts warehouses, like Sacramento Vintage Ford, Mac's Antique Auto Parts, Dennis Carpenter, Classic Haulers, and Rhode Island Wiring will have the wiring harnesses. Keep in mind that there isn't one comprehensive wiring harness. You will need to buy several harnesses to complete the truck. For example, there are separate wiring harnesses for the engine, headlights, fuel tank sending unit, dome lamp/courtesy lights, instrument panel, etc. I'm sure that you can call either of the repro parts warehouses and tell them that you need wire harnesses to complete your truck and they'll be able to tell and sell you exactly what you need. The harnesses are color-coded in factory colors. It'll be easy to rewire the truck by using the factory wiring diagram.
