390 vs. 429/460 - Page 2 - Ford Truck Enthusiasts Forums
390 vs. 429/460
Old 10-16-2011, 12:44 AM
archangel archangel is offline
archangel is starting off with a positive reputation.
Quote:
Originally Posted by 85e150six4mtod View Post
" Built in the same manner, with the same attention to detail and component matching, the 460 will always outpower the 390.
Well.
In favor of the FE, the low, medium, and high rise heads offered from the factory were rather sweet options, and as for the "no replacement for displacement" statement, if you got a 427 block @ a 4.23 bore and installed the 428 @ a 3.984 crank, you could get just under 450 cid with the standard bore
4.23 X 3.984 = 448
and with the recommended maximum .030 over bore gets you
4.26 X 3.984 = 454
That's only 6 cid shy of the stock 460.
4.36x3.85 = 460
Install the high rise heads, intake, and a few other go fast goodies and I think a 454 FE could give the 460 one H3LL of a run!
Stroking the 460 is another thing!
Old 10-16-2011, 12:47 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Quote:
Originally Posted by archangel View Post
Well.
4.23 X 3.984 = 448
4.26 X 3.984 = 454
4.36x3.85 = 460
All that will only cost you 4 times what the 460 cost. Not a reasonable way to go.
Old 10-16-2011, 01:03 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Well.
4.23 X 3.984 = 448
4.26 X 3.984 = 454
4.36x3.85 = 460
"Built in the same manner" would not mean a custom, high performance 390 or 427--now that you're talking 4.23 bore, it's not a 390--vs. a stock 460. I can find enough stuff on line in 90 seconds to do the same things to a 460, bringing it up in true mountain motor territory, and far outpowering your examples.
Old 10-19-2011, 06:18 AM
Breaker Breaker 3-3's Avatar
Breaker Breaker 3-3 Breaker Breaker 3-3 is offline
Breaker Breaker 3-3 is starting off with a positive reputation.
if we're talking about 4x4 though....
and i've got an NP205 t-case...what's performing better at 0-30 mph...more torque and power?
I understand that the 460 without a doubt is gonna outrun the 390 on the highway or race settings....but whatabout street and off road??
tuning, efi and cam all the same let's just say or at least setup the engines with this in mind....
Am i missing something here or just pulling for the 390???
Old 10-19-2011, 08:13 AM
The FE series engines were around winning races long before your 460 was even in it's diapers!
Have some respect for your elders!
Don't make grandpa go get his walker and run your toe over!
Old 10-19-2011, 08:53 AM
79superduty 79superduty is offline
79superduty is starting off with a positive reputation.
1968--428 cobra jet 335hp. 440 tq. 1969--429cobra jet 365 hp. 450 tq.
Old 10-19-2011, 09:57 AM
kenjh's Avatar
kenjh kenjh is offline
kenjh has a good reputation on FTE.kenjh has a good reputation on FTE.
never believe all you read..
Old 10-19-2011, 10:43 AM
If you want to compare Hi Riser drag motors or Le Mans motors to low compression pillow barge 460s, go ahead.
As for low end and drivability, again, if you build both engines the same way, the 460 has more low end and both drive just fine.
Old 10-19-2011, 05:26 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
Really the only advantage the FE has is less weight. Like has been said, if they are built the same the 460 is always going to beat a 390 (in every way) and it's going to do it for less money.
It's not as cool though!
Old 10-19-2011, 06:13 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Swapping from a 400 to either an FE or 429/460 really comes down to which parts are more easily sourced. For pre-79 trucks, the FE stuff is far more plentiful (mounts/towers/radiator&hoses/accesorries&brackets) whereas the 80+ trucks have more 460 parts available.
Some of the newer 80+ parts can be used for assisting a 460 swap into an older truck, but not all.
Of course, the 400 shares the bellhousing pattern with the 429/460, so that takes away one hurdle right off the bat.
I agree with sleepy though, the FE is cooler, even if it doesn't have quite the power potential of a well built 460.
Old 10-19-2011, 08:48 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
The FE is cooler and more retro. I'm running a 428 cj in my mustang. However if not trying to stay stock or period correct the 385 block has many more options available at better prices. 460 ci. stock is much cheaper than bringing a 428 to 460 ci standards. Do the math and determine what your end goal is.
Old 10-20-2011, 07:01 PM
Quote:
DUDE!! you forgot to mention that because this is the FE thread we get a 50 point lead and any other engine gets a 25 point penalty, so the FE is 75 HP ahead before the key is even turned!
  #28
Old 10-20-2011, 09:24 PM
91Bronc300 91Bronc300 is offline
91Bronc300 is starting off with a positive reputation.
Quote:
Originally Posted by kenjh View Post
I have a 428 in my 79 bronco ,on propane
If you don't mind the thread hijack, what kind of mixer are you running on your propane 428? Just a single Impco 425?
  #29
Old 10-20-2011, 09:38 PM
kenjh's Avatar
yup just the little single right now ..but I do have a duel mixer I want to try after I get a locker for the rear ..that should find the next weak part..for the record ..I LIKE MY 428 !!! and my 7.3 diesel .and the crappy little 1600 cc in my ford Anglia was fun too..build what you want ..enjoy.. don't waste time you can play with getting annoyed with someones preference,your motor your choice ..enjoy ..I am gonna go play with my 54'flathead..all 239 cubic inches...lol...
  #30
Old 10-20-2011, 09:58 PM
That's kind of surprise. I've got most of the stuff to do a propane conversion on a 400, but was wondering how to let that much motor breathe because I just want to use a single Impco 425 to keep things simple. Was thinking of just leaving the motor a 351M to prevent undercarburetion even though I didn't really want to do that. Your 428 feel like it runs out of air before it does cam?
Keep 390 or go 460 Killgore 1973 - 1979 F-100 & Larger F-Series Trucks 21 07-12-2013 12:12 PM
Advantages of 390 over 460 zerfetzen 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-06-2010 10:05 AM
Would a 460 intake fit a 360-390 ?? rsalter66 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 07-27-2009 10:29 AM
390 vs 460 cowboy.2010 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 29 02-08-2009 06:13 AM
New Style Power Steering pump for my 390? 78ford351m 1973 - 1979 F-100 & Larger F-Series Trucks 15 12-05-2008 09:25 PM
Tags
1973, 390, 429, 429460, 460, air, build, compresser, f150, ford, forums, gas, mileage, motor, mudding, smith, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
