Petronix for a 62 F100 223 6 Cyl - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 09-26-2011, 03:27 PM
BeerKnurd's Avatar
BeerKnurd BeerKnurd is offline
BeerKnurd is starting off with a positive reputation.
Has anyone else gone the Electronic Ignition route? If so, could you tell me what Petronix part number you went with? Do our trucks run 12 volts or lower? How can you tell for sure? Thank you!
Old 02-08-2015, 04:55 PM
Koolkat Koolkat is offline
Koolkat is starting off with a positive reputation.
Pentronix
I have a '62 292/auto. I have a Pentronix in it and I would do it again. I don't know what part number you would need for yours but make sure that they are lined up properly both air gap and height. Mine missed on one cylinder, I couldn't figure it out. I called the hot line and they told me to make sure that the pole piece and the pickup were on the same plane. I shimmed the pole piece with an O-ring and it solved the problem. Good luck. Install the Speedway disc brake conversion also you won't regret it.
Distributor Stogey 1961 - 1966 F-100 & Larger F-Series Trucks 10 01-02-2017 10:18 AM
61 F100 w/ 223 carb options? IDIoit 1961 - 1966 F-100 & Larger F-Series Trucks 6 04-30-2016 08:02 AM
Petronix I 1281 install into 64 F350 w/ 292 ihcc104 1961 - 1966 F-100 & Larger F-Series Trucks 11 04-16-2016 08:13 PM
Petronix? Mitch1129 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 02-23-2015 10:50 AM
more flatty questions 55 f350 Flathead V8 & Flathead 6 3 03-30-2009 06:15 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1962, 1963, 223, 62, 6cy, f100, ford, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
