engine coolant drain plug - Ford Truck Enthusiasts Forums
Old 09-26-2011, 12:45 PM
menzfamfour menzfamfour is offline
menzfamfour is starting off with a positive reputation.
i have a 2002 f150 i am changing the coolant and i cant get a socket to fit that little plug is there a special tool please help thank you
Old 09-26-2011, 02:05 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Your not using radiator drain **** at bottom passenger side?
Old 09-26-2011, 03:25 PM
no i mean the engine drain for the coolant nothing seams to fit it do i need a special socket
Old 09-26-2011, 03:27 PM
i have tried all my sockets and i am starting to strip the drain
Old 09-26-2011, 04:24 PM
DanielB DanielB is offline
DanielB is starting off with a positive reputation.
Why are you pulling the block drain? To change the coolant you only need to drain the radiator from the drain **** on the bottom of the radiator. no need to jack with the block drain.
Old 09-26-2011, 04:57 PM
in the manual i tells you to drain that plug
Old 09-26-2011, 06:12 PM
should i forget to pull the engine plug
Old 09-26-2011, 06:14 PM
I've never done that. On any vehicle I did a coolant flush on I'd drain the coolant. fill with water, run the engine for a bit drain again. then refill with correct coolant/water mix.
Old 09-27-2011, 01:28 AM
Torky2 Torky2 is offline
Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.Torky2 has a very good reputation on FTE.
I pull block drain plugs whenever possible. A 460 holds many quarts in the lower water jacket. Even the smaller engines hold quite a bit.
By using the radiator drain, or pulling the lower radiator hose, all the water in the block below the water pump passage level stays in the block. There is an upper common area, that pulling either side's block plug will drain. And a lower water jacket area (one each side of the engine) that only the plug on that side will drain.
I've pulled out the driver's side block plug on the '97 4.6L with no problem. Can't tell ya what wrench I used, don't remember. But it was no big deal. I used #1 Permatex (the setting type) on the plug threads before putting it back in.
Block drain plug on the passenger side on many V-engines are blocked by the starter. Pulling those on old engines can be a good idea. May pull the plug... and nothing comes out! Have to poke a thin steel rod in to dislodge crud, or casting sand that collected there at the bottom of the water jacket.
Old 09-27-2011, 08:01 AM
paker paker is offline
paker is starting off with a positive reputation.
I don't know what engine you have. But on mine, the drain plug is a square head. I used adjustable wrench. It is a good idea to drain the block, but if you cannot, don't lose sleep.
Old 04-14-2012, 06:05 PM
Rob1109 Rob1109 is offline
Rob1109 is starting off with a positive reputation.
97 with 4.6
I also would like the drain the block. Approximate location for both left and right side? Are these the square headed things? Can they be reached from the top side? Advice and counsel appreciated. Best.
Old 04-14-2012, 11:08 PM
I don't have 4.6 but afaik engine drain plugs are square heads. I doubt you can access it from above. YOu should see one on each block.
Old 04-15-2012, 12:11 AM
Quote:
Just had my driver's side out a month ago. On my 1997 4.6 WINDSOR engine (VIN code "6" for 8th VIN digit), it is an internal hex plug. I use a metric hex that is fitted into its own socket, driven with a 3/8" drive, a Craftsman Metric Hex 3/8" drive set I have. I put an extension on it, and it is easy to get to.
The driver's side block drain plug is about 2" above the rear-most core plug ("freeze plug") on the block. On my 2WD, it is just above and a bit forward of the oil filter. Easy to get to sliding under from behind the left front wheel.
Once it's really loose, I just spin the extension by hand and slide myself back, because when the plug comes out, it dumps!
Before putting some Permatex #1 sealer on it and installing it, I thread it in bare with the extension held by hand not by wrench, to get a feeling for the insertion angle needed. It has to be threaded in really straight, or else it isn't right. When you have it started right, it threads in easy.
Old 04-20-2016, 11:14 PM
safety3rd safety3rd is offline
safety3rd is starting off with a positive reputation.
do you happen to know the location of the drain plugs for a 94 Bronco 5.8L XLT? or even better a diagram?
Old 04-21-2016, 09:30 PM
Aftrmidnite Aftrmidnite is offline
Aftrmidnite is gaining momentum as a positive member of FTE.
Mines a 17mm, had to buy a 6 point. it was bugered up so I had to file it a little and tap the socket on it. I still couldn't get it. Had to put the truck on a rack, to get enough leverage. What every you do don't hammer the breaker bar or jerk on it, the plug is very soft. I got around a gallon of coolant out of the lower block. I flushed the COLD engine with a hose hooked to a Prestone flush tee. Put the plug back in started the engine, and continued till water came warm. partially drained radiator, added cleaner. Drove for three days, let engine cool, flushed thru tee, and out recovery tank, till clear. Started engine, flushed till clear. Drained block, and radiator. blew heater coil, radiator, and engine block out with 50 psi compressed air. Filled with distilled water, drove till hot, let cool, drained. Blew out system, reinstalled block plug with Never-seez. On my 4.6 L with a single pass radiator, I added 9 quarts of 100% yellow anti-freeze and topped off with distilled water. You'll have to keep topping of the coolant tank, as bubbles are worked out. A refractometer indicates -34 which is 50/50.
Oil Cooler removal - no coolant out of block plug? Frank250Tank 1994.5 - 1997 7.3L Power Stroke Diesel 9 11-12-2016 05:11 PM
Coolant question f350project 6.0L Power Stroke Diesel 7 09-03-2014 09:06 PM
1993 engine coolant drain plug mike L Cooling, Heating, Ventilation & A/C 3 07-08-2006 11:03 AM
Coolant drain plug on a 91 Ranger JakeFM Cooling, Heating, Ventilation & A/C 3 12-26-2004 09:04 PM
Proper Procedure after coolant drained from block cyberdr2 1978 - 1996 Big Bronco 8 02-02-2003 09:24 PM
Tags
07, 1994, 1997, 97, block, brand, coolant, drain, engine, f150, flus, ford, location, plug, plugs, radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
