Any old-school tricks for "loosening" a tight V-8? - Ford Truck Enthusiasts Forums
Old 09-25-2011, 11:09 PM
NightTrain55 NightTrain55 is offline
NightTrain55 is starting off with a positive reputation.
My rebuilt 428 is pretty tight. I can turn it from the front bolt on crank,but it takes a little bit of muscle. Therefore, seems like a lot of stress for the starter. We did do the initial 20 minute break-in run. Still tough on start-up! Any tricks other than just to keep on running it?
Old 09-25-2011, 11:12 PM
BlueOvalRage's Avatar
BlueOvalRage BlueOvalRage is offline
BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.BlueOvalRage has a good reputation on FTE.
Nope. It just needs to run in and it will loosen up. Just sitting and idling probably won't do much for it, either. It needs to see some loaded mileage. In the near term, as long as it starts, runs, and carries good oil pressure, you've got no worries.
Old 09-25-2011, 11:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Hastings (as in piston rings) has an excellent write-up on breaking in a fresh rebuilt engine:
Breakin Procedure
Old 09-26-2011, 11:43 PM
bobbytnm's Avatar
bobbytnm bobbytnm is online now
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
A fancy dinner and a diamond encrusted bracelet maybe......
Old 09-27-2011, 12:41 AM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
Don't forget champagne, candle light and Barry White!
Old 09-27-2011, 12:53 AM
lexcoe's Avatar
lexcoe lexcoe is offline
lexcoe is starting off with a positive reputation.
Quote:
Yeah, especially Barry White....LOL Geez you guys crack me up. John
Old 09-27-2011, 02:36 AM
iwanaflattie iwanaflattie is online now
iwanaflattie is gaining momentum as a positive member of FTE.
roofies on the champange(gasoline)
Old 09-27-2011, 12:57 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
Quote:
He said he want to loosen up the engine....he doesn't want it to forget that he broke it in!!!
Run it and make sure that your starter has good connections...especially the ground...sometimes paint on a fresh rebuild will insulate the starter a little & result in slow cranking. Also check the connection of the battery ground to the block.
Dan
"Grinding" noise from steering wheel- Normy Aerostar 10 08-13-2012 07:22 PM
Is there a trick to removing "cigarette" power point? kirkharrod 1999 - 2003 7.3L Power Stroke Diesel 3 02-26-2010 06:28 PM
Spark plug removal rjaywhit 1973 - 1979 F-100 & Larger F-Series Trucks 4 11-05-2007 01:38 PM
distributor cap tworivers Bronco II 5 08-09-2004 11:45 PM
EGR Valve - How to replace? jrocco Modular V8 (4.6L, 5.4L) 3 05-05-2003 10:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
