Is it worth getting a k&n air intake system??
#48
#50
#51
That should be cool.
This may tell you something. He plans to rebuild it in the future and do alot to the motor and still use the stock throttle body. He gave me the V8 one as a spare.
He used to have a mid 80s step side with the I6 and was built up and it would eat most V8 trucks from stop light to stop light.
Sorry for the thread hijack.
#53
On vehicles equipped with a Mass Airflow Sensor (MAF), an over-oiled K&N (or other similar type of oiled filter element including foam) filter will cause tiny droplets of oil to get into the intake air. This oil then sticks to the sensing elements inside the MAF and causes it to malfunction (and in some cases, actually causes the MAF to burn up because it can't dissipate the heat properly into the air flowing through it). This then causes the CEL to turn on.
I have several friends who are mechanics and they all confirm this (even though K&N on their website claims that this can NEVER happen!!!). You can also google "K&N MAF" and start reading. Plenty of info out there. The European-car MAFs that use a circuit board sensing element are the most prone to being damaged by the oil film BTW. The hot-wire MAFs usually can be cleaned without any permanent damage.
This. Many people don't realize that oiled air filters come over-oiled from the factory so they don't dry out and rot on store shelves (many are a cotton-based material). Proper procedure is to clean the filter, and oil according to directions- with a K&N, apply just enough oil to make the filter have a red tint, that's it. When I had my '93 SHO (a MAF car) it had a K&N, and I (stupidly) over-oiled it. Car ran like crap after a while, and I knew what it was. Popped off the airbox cover, sprayed some brake parts cleaner on the MAF, let it dry and I was back in business. The advantage I see to a K&N panel filter is that it is re-useable, so there may be some savings if your truck works/plays in dusty areas.
Someone here mentioned attaching a Donaldson gauge (or restriction gauge) to the air intake system- while it works well for turbodiesel engines, it doesn't work well on N/A low displacement engines. GM began putting them on all the trucks and SUV's and I've never seen one actually work as intended.
Simply put, here is what I would do:
-Clean your throttle body and upper intake via IV-style system (vacuum line). Seafoam even makes a spray one now. Get all the PCV and EGR buildup out of there.
-Insulate the ducting going from the throttle body to the airbox. Heat rises, and will become trapped near the hood and top of the engine compartment, moreso when the air is being heated by the radiator.
-Insulate/isolate the airbox itself. Metal has reflective properties, but transfers heat well (hence the use as a heatsink). Quality intake systems are composite, which does not transmit heat as readily.
-Create an unobstructed means for air to get into the airbox. The 300/460 is the one to use based off of the consensus here. Insulate that ducting too. Make sure it's unobstructed, however, don't let it become a vacuum for water and large debris. Many import guys have hydrolocked engines due to the "cold air intake" drawing in air from behind the front bumper. Great spot for cooler air, but it's also a great spot to suck up water from that puddle you underestimated.
-Ensure the rest of the truck is healthy. I used to own a Typhoon, and the first rule to making them fast was to make sure they ran perfect in stock form. You'll pick up lost power and mpg by changing plugs, wires, cap & rotor, and the fuel filter. No binding pulleys or broken catalyst either, lost power there. Low tire pressure makes you slow too. (and kills mpg)
-Uncork your exhaust as well. It'll only breathe in as much as it can breathe out. Make sure there's still a convertor or some sort of device to create some backpressure and create a scavenging effect. I have a 70 series Flowmaster on my truck, and like the article reads, I can tell where the hotspots are. I sprayed down my new parts with 500* engine enamel....it wasn't enough. Burned off and left white ash on everything from the O2 to the back of the muffler. (I don't have a cat).
#54
I don't consider the fact that KN is reusable to be an advantage. Its more of a hassle. The cleaning, drying, reoiling, etc. I'd much rather just replace it. If I ever did get a high flow filter, it would be AEM or AFE dry flow. Those just need to be rinsed out and allowed to dry, and require no oiling.
I think that wrapping the intake tubes to create a thermal barrier is a decent idea, but I never got around to trying it.
I completely agree with the intake cleaning, tune up, fuel filter etc.
Do not use carb cleaner.
Your so right. If its not running optimally in stock form, modding it won't do much.
#55
#56
Whoever said that an air filter restriction gauge doesn't work on a gasser doesn't know what they are talking about! All it is is a differential pressure sensor that latches at the highest pressure difference that it sees (so if you are experiencing a restriction at WOT, it will latch or 'remember' what the maximum restriction reading was).
The real reason why this person probably thought that they don't work is that it TAKES FOREVER for the filter element to get clogged enough for there to be a significant pressure drop and make the gauge indication move. One of the large shipping companies (Fedex or UPS, can't remember which) was finally talked into installing Filterminder air filter restriction gauges on their trucks back in the 1990s. The discovered, with the commensurate significant cost savings, that on average you could get 100K miles or more on the same filter element.
Unnecessary filter changes are one of the biggest profit centers in the automotive service business today! I ran the same filter on my 1988 Buick for about 120K miles (paper, OEM), and when I finally changed it, I noticed no power or fuel mileage improvement (meaning that the old filter was still working just fine).
You can get an air filter restriction gauge for under $20 (less than the cost of one filter these days) and install it on your airbox in a half hour or so. Here's just one of many available out there:
Amazon.com: Wix 24801 Air Filter Monitor Kit: Automotive
Heck, even K&N sells one:
K&N Filter Minder
K&N Filter Minder
#58
I believe it is a perfomrance enhancer to force as much air into the engine as possible. A filter that flows more air is therefore a component of this process.
The filter alone won't do much. The filter needs to be combined with a forced air induction system that takes outside air from the radiator support area, and forces it into the throttle body, much like a passive supercharger.
My truck used to have such a system from the factory, until it deteriorated from the sun and/or heat. Now I'll have to fabricate something to take its place. The Arizona sun eats plastic, cloth, and rubber. But, I guess not having a spec of rust anywhere compensates for that.
#59
K&N Filter Minder
K&N Filter Minder
I put a K&N cone filter on that Cummins and it was a much better running machine, throttle response was improved. I ran it to 243k miles and never had a problem with oil getting into the air tube (I checked for it) even though that truck had a turbocharger on it about a foot from the filter sucking air through it faster than our gas engines ever will.
#60
