Water seperator warning - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 09-25-2011, 07:49 PM
Rob381 Rob381 is offline
Rob381 is starting off with a positive reputation.
My water seperator warning light came on while driving today, but after i drained it, the only thing that changed was the wrench warning light is now on also. I have drained the seperator four more times and every time there was no water in the seperator. Could the sensor be bad? As for the wrench the only thing I found on that is for the DPF needing to be de-ashed. The truck has 125,000 miles on it and I got the lattest flash a month ago. I usually get my fuel from Shell and add Power Service Cetane booster. I have a SCT livewire and dpf delete pipe ready to go on. Hope this is enough info.
Old 09-25-2011, 08:55 PM
bigcountryfs bigcountryfs is offline
bigcountryfs is starting off with a positive reputation.
mine did that once and i had gel built up at the sensor. i had to remove the drain spout and the filter and use my air hose to blow thru the holes where the drain spout was to the filter hole. use low pressure and watch o-rings.
Old 09-25-2011, 09:13 PM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
The HFCM can get clogged up with gunk and cause problems with the sensor, but I think it's likely that your wrench light is something different. I would suggest getting it checked out by your local Ford dealer. This could be a serious problem, I would get it checked out ASAP.
Old 09-25-2011, 10:06 PM
Jessef250 Jessef250 is offline
Jessef250 is starting off with a positive reputation.
The wrench light comes on when the water separator light comes on. Thanks to the new flash, nothing major. Get a water separator sensor, take the fuel filter out and spray b-12 through the sensor hole and clean best as possible. I wouldn't suggest air hose! But this is what we do at the dealership!!
Old 09-26-2011, 06:07 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
What makes you think they DPF is bad BTW?
Old 09-26-2011, 10:09 AM
Quote:
The only mention I saw of the wrench warning light was in the suplement manual on page 47. It stated the filter may need to be removed for ash cleaning at 120k and I'm at 125k.
Old 09-26-2011, 10:11 AM
Thanks for the great info guys. I will try cleaning it out today and let you know if that was the issue.
Old 09-26-2011, 12:53 PM
Rob381, are you going to clean the dpf first?
Old 09-26-2011, 01:31 PM
So while I was looking at the HCFM to see what I needed to clean it out I diconnected the sensor and reconnected. This seems to have cleared out all the faults. I still plan to take it apart and clean it but its running great now. As for the DPF delete there is a problem with the Livewire device and I have to send to SCT to udate the firmware. Thanks again for the great info guys.
Old 08-20-2014, 07:55 PM
Slick60ZX14 Slick60ZX14 is offline
Slick60ZX14 is starting off with a positive reputation.
Got a question.... I have a 2008 Ford F250 Super Duty 6.4 and was going down the road the other day and the wrench light came on.. then the panel lit up that the fuel/water separator needed draining... but I also noted a loss in power.. how much fuel is suppose to run out of the separator before it stops???... the key is out, and ignition is off... and I have run out 2 gallons and it will not stop running... it acts like it wants to drain the tank...
Old 08-20-2014, 09:50 PM
senix's Avatar
Quote:
After about a pint you are doing no good. Any water is out by now.
If you have reduced power then I would advise a tow. You have water throughout the system.
Old 08-21-2014, 07:38 AM
bubbasz1's Avatar
bubbasz1 bubbasz1 is offline
bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.bubbasz1 has a very good reputation on FTE.
When you drain the separator do it into a glass dish so you can see if there was water in it. Could be that your sensor needs to be cleaned also. As above you only need to drain a pint or so to get the water out, if you still have water in the system after the first pint you have a contamination issue that needs to looked at. Water is not your friend, drive as little as possible or not at all if you think you have a bad batch of fuel.
Old 08-21-2014, 07:24 PM
Tawn's Avatar
Tawn Tawn is offline
Tawn is gaining momentum as a positive member of FTE.Tawn is gaining momentum as a positive member of FTE.
I had the EXACT same symptoms. It was a flogged up fuel/water separator.
See my thread on it:
http://www.ford-trucks.com/forums/13...ch-symbol.html
6.4 wrench light/ drain water seperator Tanner Jones 1999 to 2016 Super Duty 2 12-04-2016 02:24 PM
water seperator leak. 2008 6.4l markturik 6.4L Power Stroke Diesel 2 10-03-2016 06:20 AM
Cetane Booster cowboyacg 1999 to 2016 Super Duty 3 07-19-2016 01:51 PM
water separator and wrench light on? SUPERDUTY_08 6.4L Power Stroke Diesel 11 03-08-2015 10:15 PM
Water seperator Harkeyms 6.4L Power Stroke Diesel 32 03-08-2015 03:36 PM
Tags
1999, 2003, 64, diesel, f150, f350, ford, gas, light, sensor, separater, separator, seperator, spraying, warning, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
