Go Back   Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-25-2011, 05:30 PM
longm longm is offline
1964 Ford Econoline Pickup
longm is starting off with a positive reputation.
Help needed with Spindle bolt locking pin removal
I need to replace the king pin and bushings on a 1964 Econoline Pickup and am have trouble removing the locking pins. The manual states that the pin just needs to be drived out, but mine will not budge. Any tips for removing the pin would be greatly appreciated.
  #2 (permalink)
Old 09-26-2011, 08:38 PM
GLR's Avatar
GLR GLR is offline
Garage is empty, add now
GLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputationGLR has a superb reputation
I assume you took the nut off. It's a tapered pin, pound on the threaded side.
__________________
[/SIGPIC]George 54 F100, 78 F150, 79 F150, 86 F250, 87 F250 Member #5 Boy you ain't Right Club Official Slackmaster #15
  #3 (permalink)
Old 09-27-2011, 07:10 PM
Hi Gorge - that is the problem the 64' does not seem to have a bolt, just a pin. Since I need to clean up the axle, I will just remove it and have the pin pressed out at the shop.
Thanks
Mike
  #4 (permalink)
Old 09-27-2011, 07:39 PM
GLR's Avatar
GLR GLR is offline
Just checked some pics. The pin is tapered so will only go out one way. Your 64 has the threaded top where the grease fitting goes. You have to be careful driving the pins out or the threads in the spindle can be damaged. Don't ask how I know.
__________________
Tags
1964, bolt, econoline, fit, ford, king, kingpin, lock, locking, pick, pin, removal, remove, replacement, spindle, spindles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
