Sticky Ignition Key Position
I have this issue with my ignition switch getting stuck on the "ON" position. I'm getting tired of having to remember to back off the key to a safe position, lol. Do I just replace the Ignition switch? or do I replace the whole assembly (switch, mount, bezel & cylinder)?
Thx!
Thx!
I have just replaced my ignition switch because it would stick and let the started motor run-on. After seeing the internals, the WD-40 should clean it up. There is a dab of factory installed grease at the end of the ignition key cylinder that is probably solidified or gunked up. With your key and a paper clip you can remove the lock cylinder for closer cleaning and lubrication.
If it makes you feel better though, please do so.
John
DieselCamper
08-26-2016 10:21 PM
krautwolf
02-08-2005 06:33 PM
