fuel gauge stuck on Full
Well besides the pyro breaking friday BEFORE live tuning,and the exhaust leak I gained on the way to Texas(not inpart of the pyro not working). Now the fuel gauge is stuck on full. It looks good,200+ miles and still on full. Haha. Anyone have suggestions? Could it be the gauge,or possibly just the sending unit? Maybe a fuse?
Just guessing here...It sounds like the float may be stuck in the cap area at the top of the tank. Maybe give the tank a hit or two with a rubber hammer to see if it frees. I really doubt the gauge - I don't recall anyone's gauge going kattywhompass. The other thing I can think of is a bad sender unit.
I remember someone mentioned the same problem you are having and they found chafed wired when they dropped the tank. Dropping the tank is easy (just run here real low of fuel and then siphon the rest) and use a floor jack with a sheet of plywood on it. Might as well do the in-tank mods while you have it down, if you haven't already.
Aren't these newer tanks baffled to prevent sloshing? If not, then I am hoping my gauge's problem is the float on the sending unit is stuck in the up position by said wires. It reads full always for the last two months.
Reading this thread proved that. more rhetorical than anything. Judging from my own experience on this problem it would make sense to baffle long larger tanks like mine with 38 gallons and laid longitudally. I'm hoping it is tangled, but ticked I have to drop the tank to see. I've never had any of my cars go bad on fuel gauge units. And I have owned many Fords.
I have a similar problem. Gauge is stuck on past full, but have noticed when I first turn it on it will show around 3/4 which looks to be about right for how many miles since last fill up. Problem is in a few minutes it goes back up past full?? Doesn't seem like that would be a stuck float does it. Any Ideas.
