How do I test PCM - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
How do I test PCM
Old 09-25-2011, 10:40 AM
Shambelous Shambelous is offline
Shambelous is starting off with a positive reputation.
How do I test PCM
I have a 2001 Exp giving a P0352 code. plug good,COP good. Hodo I test PCM?
Old 09-25-2011, 11:56 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
For which cylinder did you test the plug and COP?
Old 09-25-2011, 12:07 PM
#2 which was the indicated bad cylinder with the P0352 error code
Old 09-25-2011, 12:12 PM
Just checking, I wasn't intending to insult. You'd be surprise at how many people get the wrong cylinder. Now back to my question, sorry I wasn't specific. What I was really looking for is the physical location of the cylinder you checked. As in which side and how far back from the front. The #2 is the second one back on the passenger side. Is that the one you checked?
Old 09-25-2011, 12:19 PM
Didnt mean to be a smart ***. Im relatively new to working on engines and just wanted to give good info. I checked the 2nd cylinder back on the passenger side. COP is good and new plug. there is a problem with the connector coming off harness in that the clip mechanism is broken so connector is not locked in.However when I manually held connection tight while the engine was running no improvement was apparent with rough idle.
Old 09-25-2011, 12:52 PM
Quote:
To me it sounds like your PCM is good. Based on the P0352 code I'd say you're on track with the harness connector. That code usually means that you have a connection to the COP but it's not a good one. So what you're looking to solve is a high resistance issue.
Old 09-25-2011, 01:21 PM
Ive got a 1999 crown vic. Can I clip connector of it and sodder to faulty clip on Exp
Old 09-25-2011, 02:04 PM
If the clip fits, wear it!
Old 09-26-2011, 03:54 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
How is the clip on the #2 injector? Is it on and tight? Be careful when working arount the COPs as they put out a very healthy jolt.
Chip fried my pcm. Gearhead2832 1999 to 2016 Super Duty 4 10-07-2016 12:54 PM
PCM Disassembly draggin the line Modular V8 (4.6L, 5.4L) 3 09-16-2015 06:24 AM
How to test a PCM williameub 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-01-2015 11:05 PM
PCM '08 f350 6.4 location cwstanley 6.4L Power Stroke Diesel 2 05-01-2012 09:07 PM
PCM test pin locations cruzer17 1999 - 2003 7.3L Power Stroke Diesel 3 06-04-2011 09:57 PM
Tags
03, 1996, 1997, 1999, 2000, 42l, control, expedition, f150, f250, ford, module, pcm, powertrain, test, testing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
