1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
obd scan tool won't link
Old 09-25-2011, 09:44 AM
2004F250superduty4X4's Avatar
2004F250superduty4X4 is offline
i bought an innova 1303 scan tool, did update, upgrade for abs. Tool says unable to establish a link with vehicle. It said this before i updated the tool also. is there a password on my vehicles computer or something? Code reader works on my dads dodge so i'm assuming it isn't the problem.
Old 09-25-2011, 10:00 AM
Pili's Avatar
Pili
Pili is offline
Is the cigarette lighter working? If it isn't check the fuse. The OBDII port and it share the same fuse
Old 09-25-2011, 10:04 AM
Yes both the power point and the cigarette lighter work.
Old 09-25-2011, 10:17 AM
Pili's Avatar
Pili
Pili is offline
Are you sure its compatible with a SD. I'm not familiar with a lot of the scanners on the market.
Old 09-25-2011, 10:31 AM
Ok I don't know what sd is but I am new to all of this and I THOUGHT that this scanner was compatible with all '96 and newer ford, Chrysler, and Chevys.
Old 09-25-2011, 10:32 AM
And I appreciate the help.
Old 09-25-2011, 10:36 AM
Pili's Avatar
Pili
Pili is offline
SD is short for super duty, I've only used snapon and HD ( Harley Davidson) scanners. sorry i cant be more help
Old 09-25-2011, 10:40 AM
Thank you again
Old 09-25-2011, 10:42 AM
MOpartsguy's Avatar
MOpartsguy
MOpartsguy is offline
Do you have the Key in 'Ignition on, engine off' position? It is a compatible scanner.
Old 09-25-2011, 11:02 AM
According to the website it is a compatible scanner for this pickup. And yes I do have the key on. It doesn't seem to work with the engine running either.
Old 09-25-2011, 11:07 AM
MOpartsguy's Avatar
MOpartsguy
It will not link properly with the engine running. Try a DTC reader from a local parts store to see if it is the fault of the scanner or truck. This will eliminate whether the scanner you purchased is a bum tool or not.
Old 09-25-2011, 11:24 AM
I'll give that a shot. It did read the code on a dodge though. Thank you
Old 09-25-2011, 11:54 AM
ToMang07's Avatar
ToMang07
ToMang07 is offline
PSD's are not OBDII compliant. You may get some codes, but generally speaking you need a higher quality scanner to scan a PSD.
Old 09-25-2011, 12:04 PM
Mark250's Avatar
Mark250
Mark250 is offline
To piggyback on ToMang's post-I have a Scantool that works great with several vehicles so far, but it is very limited when it comes to Power Strokes. Did finally get it to connect to my PSD, but about all I got were a couple of things like engine rpm. I did have some trouble establishing communication, which I don't normally have with other vehicles.
Old 09-25-2011, 12:09 PM
the website states that if the vehicle has a sticker under the hood that has OBD II Certified, it will work on that vehicle. this pickup has that sticker. Is this not accurate?
Quick Reply: obd scan tool won't link
