1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Manual Transmission pops out of 3rd gear
Old 09-25-2011, 06:18 AM
bookpile's Avatar
bookpile
bookpile is offline
I have a 2010 5.4L F-250 that has the six speed in it. I bought it used with 16k on it. Ever since I owned it, it will occasionally pop out of third gear and grind when you try to put it back in. At first I thought it was just me not pushing it up in far enough, but it's been happening a little more frequently.
Unfortunately, it's not repeatable. It happens during random temperatures and under various load conditions.
I just dread taking it to Ford, when I can't even show them the problem. It is Ford Certified so the powertrain is covered to 100k.
Does anyone have any experience or thoughts?
Thanks
Old 09-25-2011, 07:09 AM
bfife's Avatar
bfife
bfife is offline
still plays with trucks
does it seem to just pop out when you're just cruising or let off the throttle? that usually indicates a posssible bad pilot bearing letting the main shaft wobble around. other wise it probably a broken set of syncros.
Barney
Old 09-25-2011, 09:09 AM
nitrogen's Avatar
nitrogen
nitrogen is offline
could be a damaged sliding shift collar. either way its not right. you have nothing to lose by asking if the tranny is covered and telling them to fix it. if you have the tranny down I personally like to at least look at the clutch to see how much life it has left. dropping the tranny is 95% of clutch replacement labor
Old 09-25-2011, 08:56 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
If the clutch is bad at 16k that could very well indicate a problem with the tranny. Have Ford look at it. If nothing gives them an indication there is a problem you might have to live with it untill it becomes a problem. Did you/they do an Oasis report before you purchased?
Old 09-25-2011, 09:19 PM
nitrogen's Avatar
nitrogen
nitrogen is offline
He never said clutch was giving issues. I just suggested it because if tranny was out, clutch is only another 15 minutes to look at and make sure of is in top shape
donniezyea
05-16-2008 03:00 AM
bocephus_3349
06-30-2007 03:50 PM
drumlinecowboy
General Automotive Discussion
02-12-2006 08:26 AM
dhaywood77
07-03-2003 11:43 PM
400m
Bronco II
03-29-2002 04:09 PM
Quick Reply: Manual Transmission pops out of 3rd gear
