Manual Transmission pops out of 3rd gear
I have a 2010 5.4L F-250 that has the six speed in it. I bought it used with 16k on it. Ever since I owned it, it will occasionally pop out of third gear and grind when you try to put it back in. At first I thought it was just me not pushing it up in far enough, but it's been happening a little more frequently.
Unfortunately, it's not repeatable. It happens during random temperatures and under various load conditions.
I just dread taking it to Ford, when I can't even show them the problem. It is Ford Certified so the powertrain is covered to 100k.
Does anyone have any experience or thoughts?
Thanks
Thanks
could be a damaged sliding shift collar. either way its not right. you have nothing to lose by asking if the tranny is covered and telling them to fix it. if you have the tranny down I personally like to at least look at the clutch to see how much life it has left. dropping the tranny is 95% of clutch replacement labor
donniezyea
05-16-2008 03:00 AM
bocephus_3349
06-30-2007 03:50 PM
dhaywood77
07-03-2003 11:43 PM
