Manual Transmission pops out of 3rd gear - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-25-2011, 07:18 AM
bookpile bookpile is offline
bookpile is starting off with a positive reputation.
I have a 2010 5.4L F-250 that has the six speed in it. I bought it used with 16k on it. Ever since I owned it, it will occasionally pop out of third gear and grind when you try to put it back in. At first I thought it was just me not pushing it up in far enough, but it's been happening a little more frequently.
Unfortunately, it's not repeatable. It happens during random temperatures and under various load conditions.
I just dread taking it to Ford, when I can't even show them the problem. It is Ford Certified so the powertrain is covered to 100k.
Does anyone have any experience or thoughts?
Thanks
Old 09-25-2011, 08:09 AM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
does it seem to just pop out when you're just cruising or let off the throttle? that usually indicates a posssible bad pilot bearing letting the main shaft wobble around. other wise it probably a broken set of syncros.
Barney
Old 09-25-2011, 10:09 AM
nitrogen's Avatar
nitrogen nitrogen is offline
nitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant future
could be a damaged sliding shift collar. either way its not right. you have nothing to lose by asking if the tranny is covered and telling them to fix it. if you have the tranny down I personally like to at least look at the clutch to see how much life it has left. dropping the tranny is 95% of clutch replacement labor
Old 09-25-2011, 09:56 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
If the clutch is bad at 16k that could very well indicate a problem with the tranny. Have Ford look at it. If nothing gives them an indication there is a problem you might have to live with it untill it becomes a problem. Did you/they do an Oasis report before you purchased?
Old 09-25-2011, 10:19 PM
nitrogen's Avatar
He never said clutch was giving issues. I just suggested it because if tranny was out, clutch is only another 15 minutes to look at and make sure of is in top shape
3 on the tree second gear pops out clark grizwald 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 11-15-2016 03:47 PM
Ford ranger SLOW in gear... Nirrtix Ranger & B-Series 0 09-18-2016 02:17 PM
'73 F100 auto transmission popping out of gear championofthesun 1973 - 1979 F-100 & Larger F-Series Trucks 4 12-20-2015 08:01 PM
2 speed rear end fsawone 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 12-25-2014 08:58 AM
popping exhaust riverguideguy 1973 - 1979 F-100 & Larger F-Series Trucks 17 11-30-2013 02:38 PM
Tags
150, 260, 3rd, ford, forum, gear, gears, international, manual, pop, pops, slipping, transit, transmission, truck, truckthrows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
