How Bad Is My Rust Problem? (PICS) - Ford Truck Enthusiasts Forums
Old 09-25-2011, 01:41 AM
MarksA-C's Avatar
MarksA-C MarksA-C is offline
MarksA-C is starting off with a positive reputation.
My trucks a 1992 F150, I live in Wisconsin, and they dump enough salt on our roads in winter that the grass damn near never grows back around the roads. I don't really have anything to compare this rust to and I am hoping for your guys 2 cents on this never ending project.
I've put a lot into this truck in the 19 months I've owned it.
ALL new brakes, Booster to Rotors.
Front end rebuild. Wheel bearings, ball joints, linkage, etc
All new u-joints (Haven't done the front driveshaft yet)
Power Steering pump and lines
Frame Repair and Strengthening (Near Steering Gearbox)
Basic tune up stuff.
Window Wiper Motor
New MileMarker hub lockers
New Front Bumper
Ton of other little things...
Still have to rebuild the steering gearbox and get new leaf springs. After that its all mechanically perfect!
Just some eye candy lol
Getting New leaf springs and shackles, so just need to sandblast and repaint the mount. Got surface but no rot.
Frame Repair from the broke off cross member and what not...
Yuck!
Only serious spot of bad rot, not structural.
Looks good to me!
My Ghetto repair for my half of the exhaust breaking off. Going to do the same to the other side.
Old 09-25-2011, 03:54 AM
kd0axs's Avatar
kd0axs kd0axs is offline
kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.kd0axs has a great reputation on FTE.
Doesn't really look too bad. I've seen these trucks much worse than yours. If you are replacing the springs and shackles, replace the bracket on the frame too. (The one that the shackle attaches to) Those are known for rusting out and breaking.
I feel your pain with the salt. They dump so much salt on the roads over here in MN it's insane.
Old 09-25-2011, 05:04 AM
mgroshong mgroshong is offline
mgroshong is starting off with a positive reputation.
Thats not bad at all. My truck is much worse then that and i'm not sweating it one bit. Takes quite a bit to get to the point it's unsafe.
Old 09-25-2011, 09:15 AM
Tote-M-Pole Tote-M-Pole is offline
Tote-M-Pole is gaining momentum as a positive member of FTE.
Your rust issue is not that bad. I see worse every time I get under my 96 F150. The comment above about replacing brackets is a good one. I have replaced those rear leaf brackets/shackels and radius arm brackets on mine. The rusted out brackets are so common the local dealer keeps them in stock.
Old 09-25-2011, 09:51 AM
96ford250 96ford250 is offline
96ford250 is starting off with a positive reputation.
A rust proofer would go a long way with that even if it was just the canned stuff its better then nothing and it will stop or atleast slow the rot.
Old 09-25-2011, 10:20 AM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
thats in pretty good shape for this state.
Old 09-25-2011, 10:46 AM
MarksA-C's Avatar
Where can I get new brackets?
Also I got one hell of a deal for a small sandblaster, going to get some use out of it cleaning the frame and other rust areas. What would be best for re-sealing everything?
Old 09-25-2011, 11:32 AM
Nickk97tml's Avatar
Nickk97tml Nickk97tml is offline
Nickk97tml has a good reputation on FTE.Nickk97tml has a good reputation on FTE.
that is nothing! you still have paint on the frame! look what Canadian winters did to my truck!
Old 09-25-2011, 11:34 AM
hoss khaos's Avatar
hoss khaos hoss khaos is offline
hoss khaos is starting off with a positive reputation.
You can get the brackets almost anywhere. NAPA has them and even crappy Auto zone does too. I highly recommend changing them because I've changed a few recently the put holes in the bed!
Your truck looks great though! It's very saveable. Mine is 20 times worse haha
Example of a broken spring hanger
I knows it blurry but you can see the holes (and the spring mount on the left side) due to broken hangers
Old 09-25-2011, 12:49 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
tbirdscott is starting off with a positive reputation.
LMAO thats nothin, come to northern B.C. and check out whats left of our trucks. There are trucks in the early 2000's in much worse shape. Yours looks pretty good.
Scott
Old 09-25-2011, 02:37 PM
F250HD Custom F250HD Custom is offline
F250HD Custom is starting off with a positive reputation.
It's POR-15 rust converter/coating time, my friend. I'd talk to a good body man first, but I think everything that's still sound could be brushed off and coated, for a fairly permanent fix. Anything that is on the edge of rusting through - like, say a cab/body mount should be fixed first, as POR-15 is very hard to remove once on - but it converts rust and protects in a way other paints/coverings can't. Popular here in Alaska. F250HD Custom
Old 09-25-2011, 08:25 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
bungee cord gas tank strap?
Old 09-25-2011, 08:31 PM
F350Kid238 F350Kid238 is offline
F350Kid238 has a good reputation on FTE.F350Kid238 has a good reputation on FTE.
yeah thats not to bad but still would take care of it. nice bungee cord
Old 09-25-2011, 08:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
That truck would be considered rust free here! And would get a good 3k$ for it!
Heres what we call minor rust!
Not my truck
Heres my 1990 F250 with 377k miles
And the funny thing is I was acutally driving this truck as daily driver, right till the end, when I parked it, I striped it down and cut the roof off.
Going through a complete restoration, with a new southern body!
Old 09-25-2011, 11:09 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
What rust?
"Rollin' Thingamajig" 1992 F150 Build MarksA-C 1987 - 1996 F150 & Larger F-Series Trucks 36 03-16-2012 06:49 PM
Whats going on here? Leaf spring replaced MarksA-C 1987 - 1996 F150 & Larger F-Series Trucks 25 12-19-2011 11:49 PM
Factory CB? JNeely 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-02-2011 01:12 PM
Rebuilding Leaf Spring Packs MarksA-C 1987 - 1996 F150 & Larger F-Series Trucks 20 08-30-2011 09:15 PM
got my wheels and new tires on 42nineranger 1999 to 2016 Super Duty 72 03-30-2009 05:13 PM
Tags
1990, 1995, area, bad, common, cooling, f150, f250, ford, frame, problem, problems, rust, suspension, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
