turn signals out
The saga continues
I replaced fuse 27 with a 20A and everything's been fine - until today. Came to work this morning and when I went to back in a spot, white smoke started coming out from behind the fuse block. It stopped after I shut the truck off. I pulled the fuse block and the 4th plug from the right on the bottom was a crispy critter. It's got a larger gauge pink wire (I assume that's power in) and several others, orange/gray, blue/pink, black pink, black/green plus a few more. If anyone has a wiring diagram of the fuse block it would be greatly appreciated. It's also concerning that the fuse did not blow, maybe that's why the PO had a smaller fuse in there? The melting occurred at the plug face where it contacts the fuse block, wish I could post pics.
The Saga Continues...
First of all, many thanks to woodnthings and paysonpsd for your help and schematics. Here's where I am now: after my fuse block fried, the reverse lights, running lights, and overhead console computer didn't work. I located another fuse block and replaced it. All that stuff works now, but now I have no power windows, interior lights, radio, and no instrument cluster. All the fuses are good and are the correct rating per the owner’s manual. The original fuse block (officially it's Central Junction Box) is part #2CT7-14A067-AN and the replacement is PM2CT7-14A067-AN, both out of ’02 CC F250s, and all the pins in the back matched. I’m pretty sure the radio, lights, and windows are related to the power saver relay, but the cluster isn’t. I’m still tracing circuits, but do I maybe need to get the VSM reprogrammed?
Lakvoodoo
06-12-2012 07:12 PM
optiboli
04-12-2006 02:51 PM
f250macdaddy
08-18-2005 05:20 PM
