2004 Ford Ranger 2.3L Surging - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 09-24-2011, 05:19 PM
2valvekid 2valvekid is offline
2valvekid is starting off with a positive reputation.
I have a 2004 Ford Ranger 2.3L 5 speed with 135,000 miles that is having the surging problem. It does it worst around 2000 RPM's, but does do it across the entire power band. I have replaced plugs, Wires and cleaned the MAF. At this time it is not throwing any codes.
Any help would be greatly appreciated. Thanks
Old 09-25-2011, 05:10 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
-try and catch a pending code
-change fuel filter/fuel pressure
-vacuum leaks
-check/change air filter and intake
Old 09-25-2011, 08:06 AM
pawpaw pawpaw is offline
pawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to beholdpawpaw is a splendid one to behold
The IAC is responsible for engine idle speed, so maybe consider removing & cleaning it with a plastic safe spray & see how it goes.
Cleaning may not last, it didn't for me, but was a good trouble shooting step. It can act out & not set any trouble codes.
Put the PCV valve & it's plumbing on your suspect list too, as it's time for replacement & I believe Ford does it for free on your engine. Maybe the vapor recovery system also if you don't have joy cleaning the IAC.
More thoughts for consideration. Let us know how it goes.
Codes indicate EGR issues Ford Breakdown Ranger & B-Series 18 11-04-2013 05:03 PM
Dtc P2004 mike yates Ranger & B-Series 43 10-01-2012 03:57 PM
2004 2.3l 3000rpm hesitation dorado Ranger & B-Series 5 10-19-2011 01:58 PM
Surging Idle @ Start-up 93 Ranger 3.0L V6 Michael Hyatt Ranger & B-Series 1 05-30-2007 04:55 PM
Need torque specs on 2.3L 93 Ford Ranger. eatmgrits Ranger & B-Series 1 08-23-2005 07:44 PM
Tags
1994, 2004, 23, 23l, belt, ford, forum, idle, liter, ranger, rpm, surges, surging, timing, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
