my 06 powerstroke starts rough when cold but when at operating tempurater it will not start at all
on
I see a lot of this do it yourself mentality to save money. That isn't always the case. I'm not saying that it is the case here, but it's something that needs to be looked at on an individual basis before one can say that you will (or even qualifiers like "should") save a ton of money.
Just something that I don't think everyone thinks about. Certainly not based on how the posts are worded.
Caveat: 2006powerstroke90 I was just using your above quote as a launching pad for my post. The main thrust of it was to be generally applied to what I have seen on various posts here, not on that particular one specifically.
Great Video on You-Tube
6.0 Liter Ford Powerstroke - High Pressure Oil Pump & Revised STC Fitting
The Ford 6.0 STC HPOP Fitting Update Kit 4C3Z-9B246-F contains:
* 1 Support Bracket
* 1 Hydraulic Pump Seal Kit
* 1 Branch Tube Adapter - Male
* 1 HPOP Adapter Fitting - Female
* 2 M6 X 35 mm Branch Tube Bolts
* 2 M8 X 60 mm Pump Bolts
* 1 M8 X 45 mm Pump Bolt
* 1 Support Bracket
on
On my DashDAQ I have it set up to where I don't have to have the gauges on the screen, but it has warning levels and when those levels are reached it lets me know and it starts to datalog other parameters that I have setup up to see if there is an issue.
* 1 Support Bracket
* 1 Support Bracket
So this kit should fix my problem
I seen gauges save $1000.00s on 1 fix
I know its hard for some people to justify when the truck is broke and the gauges isnt the part they need to get it to run
I was too scared our injectors were designed for 48 volts but 52 volts is just a touch more I think thats Alot Better/Safer
Do they even do a 58volt mod anymore??
If it IS the STC fitting that is actually causing your issue. BTW, if you haven't figured out already, I'm located in Brampton, but work in Toronto. Are you the original owner of the truck? Have you had your head studs installed yet?
sorry i ment 58v the guy at swamps insured me that i was safe getting the upgrade as long as i was not toweing 10,000lbs everyday
on
I would be concerned about that and I would seek a 3rd party's opinion on the matter and not someone from the company that might be just pulling the company line.
#28
Back to the topic at hand. Without datalogging it, when it fails to start, all of the above are simply guesses. If it IS in fact a high pressure oil system leak, isolating it would require air testing it, to pinpoint the source. The reason I asked if the OP was the original owner, is because I had wondered if these updates hadn't already been done while it was under warranty (assuming it has expired).
#29
If your programmed FICM doesn't resolve your issue, then you might want to take Mike up on his offer .............. I don't think you would regret it!
