Fuel pump or relay???
Old 09-24-2011, 11:22 AM
jplinville's Avatar
jplinville
jplinville is offline
My 250 wouldn't start yesterday, and i ran the battery down trying. I charged it up this morning, and it still wouldn't start.
It wasn't until I cycled the key back and forth a few times to cycle the fuel pump, that it finally started.
Is this a pump failure or a relay going bad?
Old 09-24-2011, 12:54 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Pretty hard to tell from the problem statement. A meter would help diagnose if it was an electrical issue. A fuel pressure gauge would help diagnose if it is fuel.
Your ears may be the cheapest tool as a first step. Can you hear the fuel pump cycle for 1-2 seconds each time you turn the key to the RUN position? If not....pull out that meter. If it does cycle then get the pressure gauge on the fuel rail.
Old 09-24-2011, 02:51 PM
jplinville's Avatar
jplinville
The pump was cycling when I paid attention to it...LOL
If it happens again, I'll listen closer. When I decided to cycle the pump a number of times, I heard it each time, and it started after cycling it.
At least I now know what to do to start it if it happens again.
Also, something I neglected to state earlier, it rained yesterday...all day. I went ahead and picked up another dizzy cap and button, just in case. I learned, after driving old Dodge trucks and cars, to keep a spare cap and button in the glove box.
I didn't swap it out yet, because it did finally start.
BRONC-OH
1997 - 2003 F150
11-21-2014 10:11 PM
wilsonjoey22
10-18-2009 08:15 AM
vance
07-27-2009 08:53 AM
jake93f150
06-29-2004 08:44 PM
honeydue3856
06-26-2002 11:37 AM
Quick Reply: Fuel pump or relay???
