what rear end do i have - Ford Truck Enthusiasts Forums
Old 09-23-2011, 11:24 PM
79CAMOFORD's Avatar
79CAMOFORD 79CAMOFORD is offline
79CAMOFORD is a splendid one to behold79CAMOFORD is a splendid one to behold79CAMOFORD is a splendid one to behold79CAMOFORD is a splendid one to behold79CAMOFORD is a splendid one to behold79CAMOFORD is a splendid one to behold79CAMOFORD is a splendid one to behold
Here is what I pulled off the rear end housing: S31 3 50 9 5A14
Old 09-23-2011, 11:25 PM
79CAMOFORD's Avatar
S318d sorry on mobile
Old 09-23-2011, 11:33 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
A 31-spline, Ford 9-inch with 3.50 gears.... it's a peg leg - no Traction Lok
Old 09-23-2011, 11:39 PM
79CAMOFORD's Avatar
I take it by calling it a peg leg its not a good rear end?
Old 09-23-2011, 11:54 PM
devino246's Avatar
devino246 devino246 is offline
devino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputationdevino246 has a superb reputation
Quote:
He just means you'll only have one wheel with traction in a sticky situation since its an open diff.
Old 09-24-2011, 12:01 AM
HIO Silver's Avatar
A Ford 9-inch is a tough rear end... even the NASCAR Sprint Cup cars (including the Yotas and Chebbies) run a Ford 9.
"Peg leg" is a euphamism meaning it is not equipped with limited slip (Traction-Lok). A burn-out won't tattoo the pavement with two beautiful stripes... just one lame one.
A limited slip or even a locker (PowerTrax or Lock-Rite) can be had for as little as $400 plus labor. The lockers mentioned above can be installed in the driveway and don't require removing the ring gear whereas the Traction-Lok does require disassembly and set-up.
Maybe even a better option is to hunt for the yards for a 31-spline center section with limited slip. If it has the tag, then look for an "L" between the gear ratio. For example, yours would have LS if the tag read 3L50. If you find one, it's a matter of disconnecting the driveshaft, unbolting the axles, pulling 'em out a hair, and then swapping the center section. A $5 tube of RTV and a couple of bottles of gear lube and yer there.
Side note... I think it's kind of ironic we're batting this thread around AND we're the only two FTE'ers in the Dentside forum currently wearing camo schemes. Check my garage and you'll see.
Old 09-24-2011, 12:04 AM
hasteranger's Avatar
hasteranger hasteranger is offline
hasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud ofhasteranger has much to be proud of
the factory limited slips are clutch type. At this point, most are worn out and you don't get reliable performance from them. They are better than nothing, but the open carriers are easier to weld solid, which is what I'm ready to do to mine.
Old 09-24-2011, 07:10 AM
77mud's Avatar
77mud 77mud is offline
77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.77mud has a very good reputation on FTE.
spools can be had cheap and work very well
Old 09-24-2011, 10:51 AM
79CAMOFORD's Avatar
Thanks guys ill keep an eye out for the limited slip
Old 09-24-2011, 12:15 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Here is what I pulled off the rear end housing: S318D 3 50 9 5A14
When 8D is typed together, the smilie face appears, unless you 'disable smilies in text' like I just did.
Old 09-24-2011, 02:32 PM
my axle has a smiley face stamped into the housing....
Rear End Lube Amish Ford Large Truck 2 08-02-2016 11:14 PM
71 f100 rear end benross71 1967 - 1972 F-100 & Larger F-Series Trucks 18 09-09-2014 05:54 PM
Rear end gears 77 2wd 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-09-2012 10:23 AM
Rear End Gear Ratio ocala562 1997 - 2003 F150 4 01-11-2011 06:03 PM
rear end noise drumrunr16 1997 - 2003 F150 3 11-16-2009 05:11 PM
Tags
1972, 350, 77, 9, car, compleat, cup, differential, end, f150, ford, gears, inch, lock, nascar, rear, rearend, sprint, traction, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
