broke shifter linkage plz help
Old 09-24-2011, 03:09 AM
bighaus75's Avatar
bighaus75
bighaus75 is offline
i have a 75 f250 with a c6 and a broke shifter linkage and im not sure how to take it of to replace it im pretty mechanically inclined and have been working on cars/trucks all my life but this is my first ford and i dont want to break anything does anyone know how to take this part off its the piece that actually bolts to the tranny any and all help will be greatly appreciated
Old 09-24-2011, 03:29 AM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
Is this the part you're talking about?
If it is, to remove it you have to first, remove the nut that holds the kickdown arm on and remove the arm. Then drop the trans. pan and valve body. The shifter arm is held in place by a nut that IIRC takes a 7/8" wrench to loosen. Remove the nut and slide the arm out.
The trickiest part of the reinstall is getting the kickdown lever and shift arm to line up with the valve body.
BTW welcome to FTE
Old 09-24-2011, 11:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
In case the manual control lever isn't what the OP is referring to, the whole enchilada is shown here:
Illustration Section A70.2 ~ Page 3.
Old 09-24-2011, 02:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thanks Bill.
Here's the illustration that Bill is reffering to.
I was going to post it but was waiting to see if this is what the OP is talking about.
Click on the .pdf link to view.
File Type: pdf
emeraldcoupe
13
11-15-2022 10:04 PM
ADOR
10-30-2013 07:02 PM
GatorSMR
09-03-2009 09:35 AM
KevinK82
07-21-2008 12:30 PM
contento
03-21-2002 02:36 AM
Quick Reply: broke shifter linkage plz help
