HELP!! Air suspension problems on 2000 Navigator - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 09-23-2011, 09:11 PM
browntown3's Avatar
browntown3 browntown3 is offline
browntown3 is starting off with a positive reputation.
Guys, Never had any problems with my air suspension until today. Got out at the grocery store and noticed it was already low, like it had released the air but didnt think much of it. Came back with a load of groceries and started home immediatley i never heard my compressor kick on and it never did the whole way home. No check suspension light or anything happend ?
I just got home and checked all the fuses first and made sure the suspension switch was on. All the fuses were fine. So im thinking i have a bad compressor but wouldnt that make the Check Suspension light come on ??
Any help or suggestions would be greatly appreciated on how to troubleshoot my suspension. I have a ton of work planned this weekend and the next couple weeks i need my Navigator for. Gotta get it fixed ASAP............Thanks guys!!
Also, this thing is totally bottomed out right now as in its the lowest ive ever seen it riding............will it do any damage to drive it this way ? i have to pull a trailer tomorrow with about 2000 lbs on it?? I'm thinking im goin to have to borrow my dads chevy
Old 09-24-2011, 08:33 AM
browntown3's Avatar
Does anyone know if you can bypass the relay to see if the compressor is getting power ? I think ive narrowed it down to either the relay or compresor? Or again would the Check suspension light come on with either of these not working correctly ?
Old 09-24-2011, 01:00 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
Quote:
The Check Suspension light should come on with nearly any malfunction of the system. You can go the the relay that is behind the bumper and fog light on the pass. side and jump around there. If the compressor comes on it is most likely not the problem. Pump the suspension up and turn the switch off once the truck is up and watch it to see where the problem might be. There are a bunch of solenoids and valves that could be the problem, first you have to narrow the search down. There is a pressure relief valve in the back of the Navigator that could be the poblem.
I'm sending you a P.M.
Old 09-26-2011, 07:25 AM
browntown3's Avatar
Update
Just an FYI for anyone that has clicked on my thread hoping for answers. I found the culprit to be a bad connection at the wiring harness on the relay. It looks like the plastic housing has gotten hot and melted slightly around one of the 4 connectors and made the connection go bad. Might want to check that also when you are troubleshooting. I dont know if thats 100% of the problem I am thinking there are some underlying factors making the harness get that hot but for now its working.
01 Navigator air suspension over inflated Masher 1997-2006 Expedition & Navigator 6 01-23-2016 03:35 PM
please help, 03 navigator problem redthomas 1997-2006 Expedition & Navigator 2 06-05-2014 08:10 PM
03 navigator wont rise/SOMEONE RESCUE US PLEASE NANDO/03navi 1997-2006 Expedition & Navigator 26 10-12-2012 03:34 AM
2001 Lincoln navigator 2x4 rear suspension problem. Mark Santos 1997-2006 Expedition & Navigator 3 07-24-2012 05:07 PM
Air Line Repair Part #2L1Z-5B322-AA Moto Mel 1997-2006 Expedition & Navigator 0 07-28-2010 05:36 PM
Tags
2000, air, check, compressor, electrical, expedition, ford, light, lincoln, motor, navigator, problems, specs, susp, suspension, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
