Constant limp mode, Please help - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 09-23-2011, 07:28 PM
duceswild85 duceswild85 is offline
duceswild85 is starting off with a positive reputation.
Exclamation Constant limp mode, Please help
Hey guys,
This is my first post, though I have been following the forum religiously since I bout my 08' 6.4 dsl F350 SRW a few months back. My truck is running great, however my buddy bought a similar truck with 105k and he has had noting but issues with it. So, to be a good friend and so I know what to do when my truck has these symptoms I'm asking for help.
Heres the deal the truck constantly falls into Limp Mode and then he shuts it down for 5 min or so then it comes right back and runs great. 20 - 100 miles later it falls back into limp mode. We took it to a local Dsl Tech and he said he doesn't think it's the HPFP because it runs fine sometimes, but couldn't give us an answer as to what it might be. Given the info what do you guys think? Any suggestions It mostly falls into limp after climbing a grade or getting warm.
Diagnostics:
P0087
Lood- 56.8%
ECT- 176
MAP- 38.3
RPM- 1413
V Speed- ??? said 5mph, I was going 60mph?
IAT- 114 deg.
MAF- 42.488
PTO- ON
Run time - 240 sec
Fuel Pressure- 3285
Command EGR- 2.3 %
P1780:
EGR Error- 21%
Fuel Level- 12.9 gal, was reading 3/4
Warm Up DTC CLR - 14
Clear distance 146 miles
BARO ( in hg) 27.1
CAT " 258.9
CAT-12- 233.2
ECU Volts- 13.552
ACC. Pedal D&E - 12.5 %
Old 09-23-2011, 08:44 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
P0087 X X Fuel Rail/System
Pressure - Too Low
This error will be set if the fuel pressure in the rail is too
low and the controller cannot regulate it to the setpoint.
20 % “overposition” of the
PCV or VCV [% PWM]
5% deviation of the fuel rail pressure
to the fuel rail pressure setpoint.
Low pressure system, wiring to
VCV and PCV, FUP sensor, pump
Based upon that code it is either a wiring, low pressure pump (down on the frame rail) or the HPFP (VCV is integrated).
Suggest two things for him. First make sure to do a filter change right now. Motorcraft filters only. When changing the engine mounted filter look into the fuel bowl. Ensure it is nice and clean and rust.
Secondly drain that fuel water separator and make sure there is no water in there at all.
Take the truck in for proper diagnostics. Hope there is still warranty on this truck.
I am thinking you will need it.
Old 09-26-2011, 12:55 PM
Ok thanks, I'll tell him what you said. Unfortunately, the truck is out of warranty. Why Motorcraft Filters? Some say it doesn't matter while others, like yourself only recommend Motorcraft. Is it just preference?
Old 09-26-2011, 01:05 PM
senix's Avatar
Because they fit properly.
Old 09-26-2011, 02:01 PM
Great! Thanks again.
Old 03-02-2013, 09:47 PM
08powerjoke 08powerjoke is offline
08powerjoke is starting off with a positive reputation.
My 2008 6.4 with 120,000 miles is a piece of s--- just like the rest of 6.4. I've had nothing but problems. Now it's stuck in limp mode and I can't figure out what it is. Diesel techs at the dealer don't know s--- either. I will never in my life buy another one.
Old 03-03-2013, 01:45 AM
Sorry to hear that, my buddy's truck ended up needing a new hpfp and now it runs like a top. The 6.4 is the best diesel I've owned.
Old 03-03-2013, 07:09 AM
senix's Avatar
Quote:
You should start your own thread and give us all the info you have on it so we can help.
Old 03-03-2013, 10:13 AM
Quote:
Your lucky, I've put probly 4k into it in last year. It needs more but I can't afford to keep fixing it everyday.any ideas on y it's stuck in limp mode?
Old 03-03-2013, 11:22 AM
DSbuild DSbuild is offline
DSbuild is starting off with a positive reputation.
Quote:
Pressure - Too Low
PCV or VCV [% PWM]
Translate what HPFP is plaese to a new 6.4 owner i cant follow all the abbreviations yet.
Old 03-03-2013, 11:25 AM
Quote:
I'm guessing it means high pressure fuel pump
Old 03-03-2013, 11:27 AM
Iam all set high pressure fule pump. I had to replace on my sea ray bow rider.
Old 03-03-2013, 11:32 AM
Thanks o8powerjoke It sounds like your not to happy with 6.4 Ijust got mine and i dont want to feel like i have to cross my fingers to use it. hope all works out for you.
Old 03-03-2013, 12:35 PM
Thanks I hope u don't have problems. I had to delete dpf cause it clogged completely,so I also had to get a tuner so I chose sct tuner, just replaced egr valve, had to replace radiator which is $900 dealer only. It's every week I have to put 100 here or 300 there into it, it's pitiful.
Old 03-03-2013, 12:45 PM
senix's Avatar
Yes HPFP is high pressure fuel pump.
P0087 P2291 crrider999 6.4L Power Stroke Diesel 4 11-28-2016 09:30 AM
Possible PCM Issue??? MKLC 1987 - 1996 F150 & Larger F-Series Trucks 44 03-31-2016 07:26 PM
2004 6.0L Excursion Transmission or Electrical or??? rjp1965 6.0L Power Stroke Diesel 4 11-03-2011 04:28 PM
"limp" mode Texas450 6.4L Power Stroke Diesel 14 11-11-2010 08:04 PM
Whys my truck in limp mode?!?! HELP 84 f250 6.9 1994.5 - 1997 7.3L Power Stroke Diesel 62 11-24-2009 05:29 PM
Tags
64, 64l, f250, forblimp, ford, fuel, fup, limp, low, mode, oil, p0087, pressure, railsystem, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
