I highly recomed oem for all sensors. Much better quality. Check all the wiring to see if you have a worn, pinched, chewed wire. I had a rat move in to the engine valley that caused me some issues.
Well I replaced sensor and it did nothing. Still in limp mode and still says accelerator pedal D circuit high even after I cleared codes. Any suggestions ?
Only thing I am coming up with is to recheck your connections at the sensor. Check the pedal and surrounding to see if maybe something is bent.
Check the pins in the wiring harness for the pcm. check for bent or pushed pins or any dirt or something.
Alright thanks. Called dealer they won't help till I give then $95. Which pissed me off sense I've spent $1500 just in parts from them in last few months.
To top it off my mirrors stopped folding in with button, I can hear it click but they don't move, and drivers side won't extend anymore. Lol. I think I got a lemon
Just manually fold and unfold and then they should work.
Took truck to dealer and they said the new sensor I bought from them must be bad so there gonna try another one. They couldn't find any other reason for limp mode. Of course they had to order it so I'll know I there right on Monday.
