Constant limp mode, Please help - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 03-03-2013, 12:31 PM
duceswild85 duceswild85 is offline
duceswild85 is starting off with a positive reputation.
Quote:
Originally Posted by 08powerjoke View Post
Thanks I hope u don't have problems. I had to delete dpf cause it clogged completely,so I also had to get a tuner so I chose sct tuner, just replaced egr valve, had to replace radiator which is $900 dealer only. It's every week I have to put 100 here or 300 there into it, it's pitiful.
Why wouldn't you want to get rid of the DPF/DOC? That was the first thing I did and the result was an additional 10mpg and 500 degrees lower EGT's. The radiator isn't dealer only. Mine was $788, you got ripped.
Whether you like it or not it was good that these items went out it actually saved you money on DD costs and the coolant should be replaced @ 100k anyways. If you want to talk about repair bills go buy a first gen 6.0 ha.
Old 03-03-2013, 12:35 PM
08powerjoke 08powerjoke is offline
08powerjoke is starting off with a positive reputation.
Any idea what hpfp is gonna cost me ?
Old 03-03-2013, 12:36 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
My 6.4 has been very good. I have 77K on it and it runs great. Got to do the maintance. Got to check your fluids all the time.
that is what I do and has served me well.
Still have my orginal radiator too.
Old 03-03-2013, 12:41 PM
senix's Avatar
How do you know that is your issue? What codes appear. Limp mode could mean a few different things. It is a powertrain protection mode..so it could be a transmission issue or an EGR issue.
Who have you taken it to that they have no idea what is wrong? Did you take it to a service dealer who knows about diesels? A Ford dealer? Did you take it to someone who has the proper equipment to access the PCM and see what codes there were?
Old 03-03-2013, 12:42 PM
Well, before we say that is the problem what codes are being thrown?
The hpfp is the last resort because it is a cab off repair and costs around $3500. Not many can do this repair in there driveway.
Old 03-03-2013, 12:44 PM
X2,
08powerjoke you said you bought the SCT go check for codes.
Old 03-03-2013, 12:47 PM
Quote:
Originally Posted by duceswild85 View Post
X2,
Ok give me 20 min or so and I'll check for codes. I have a 2 year old I'm trying to put down for nap. Lol
Old 03-03-2013, 01:00 PM
I hear ya, just write them all down then delete them. Let us know what you got. The next time it falls into limp mode think about what you were doing. Like we're you pulling a hill, were you on the throttle hard, warm/cold and so on.
Old 03-03-2013, 01:31 PM
Ok got 2 codes.
P2123 throttle pedal position sensor switch D circuit high.
P1000 systems readiness test not complete.
I cleared them but still got wrench on the dash so still in limp mode. Limp mode used to come on after truck was warm not towing or anything. Then I would shut truck off and it would go away, but would come back after little while. Now it's just stuck on. I disconnected batteries for an hr but that didnt work either. Do u know how to fix what codes say? Don't know what readiness test is.
Old 03-03-2013, 01:35 PM
senix's Avatar
The p1000 is nothing it will go away on its own
Old 03-03-2013, 01:39 PM
I the other code just a simple sensor to replace? If so do u know where it's located on truck ? Ha ha I said simple !
Old 03-03-2013, 01:42 PM
senix's Avatar
the other one is a sensor. I will have to look into that more. But my guess is on the throttle body.
Since you cleared the codes but the wrench is still on it may or maynot be in limp mode.
Getting ready to go to a function for my youngest right now but I can look later and try to locate it for you.
Google may help.
  #28
Old 03-03-2013, 01:46 PM
Google may help.
Great thanks, it is in limp mode. I'll be searching google let me know if you come up with any ideas, and thanks alot !!
  #29
Old 03-03-2013, 03:54 PM
It will fall in to limp mode if the pedal sensor isn't sending the proper signal. The throttle sensor is the pedal assembly. I believe it's sold as a unit. If you look at your throttle pedal you will see the sensor.
  #30
Old 03-03-2013, 04:00 PM
It looks like it is separate and costs about $55.
P2106 Forced Limited Power alsatropine 2004 - 2008 F150 1 02-13-2017 11:11 PM
P0087 P2291 crrider999 6.4L Power Stroke Diesel 4 11-28-2016 08:30 AM
Possible PCM Issue??? MKLC 1987 - 1996 F150 & Larger F-Series Trucks 44 03-31-2016 06:26 PM
Freakin limp cel and wrench again ajg617 6.0L Power Stroke Diesel 14 06-28-2015 06:05 PM
"limp" mode Texas450 6.4L Power Stroke Diesel 14 11-11-2010 07:04 PM
Tags
64, 64l, f250, forblimp, ford, fuel, fup, limp, low, mode, oil, p0087, pressure, railsystem, sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
