Pilot bearing for 52 three speed - Ford Truck Enthusiasts Forums
Old 09-23-2011, 07:15 PM
Scummer52 Scummer52 is offline
Scummer52 is starting off with a positive reputation.
Replacing the clutch on my 52 three speed transmission. My flywheel has a bushing, not a pilot bearing. New clutch kit includes pilot bearing. Should I press out the bushing & replace with the pilot bearing, or leave it as is. Truck has been running with combo (bushing trans spline/shaft).
Thanks!
Old 09-23-2011, 07:37 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Some folks like the bushing because even when wallered out, they don't seize up. Nevertheless, I went with the bearing, because it has less drag when the clutch is pushed in and doesn't allow any wobble.
If you look at the bearing, I'd about guarantee it's made in China. Just make sure it has grease in it before you install it.
Old 09-23-2011, 07:47 PM
Thanks for the info. This is my first rebuild of a "pre-1970" truck, so i'm learning alot. First I've ever seen with a bushing. Planning to drop the Engine & trans in tomorrow! Thanks again.
Tags
1948, bearing, f1, f100, ford, pilot, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
