Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-23-2011, 12:42 PM
thefnswits thefnswits is offline
Garage is empty, add now
thefnswits is starting off with a positive reputation.
OBD2 scan pod thing?
a few months back i saw someone post a picture of this scan-pod that told engine temp, trans temp, all that. i thought it was called proscan but i guess I was wrong. any help on what the brand is? thanks!
__________________
1999 F250 5.4 Lariat 4x4 Off-road 8' Boss steel plow
2008 Expedition Limited everything except 3.73's and air suspension!
2007 Mitsu Fuso FG4x4 dump 9.2 Boss Vplow, 2.5 yd torwel sander
  #2 (permalink)
Old 09-23-2011, 01:05 PM
MCDavis's Avatar
MCDavis MCDavis is online now
MmmmmmKayyyyy
2006 Ford F-150
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
I believe you're referring to the ScanGauge:
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
__________________
Chandler
Official Slackmaster #24
  #3 (permalink)
Old 09-23-2011, 07:26 PM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
Click the image to open in full size.
-- Chuck
  #4 (permalink)
Old 09-23-2011, 08:02 PM
Thanks guys! And chuck that was the exact picture I saw. Is it compatible with multiple vehicles? Like my 1999 f250 5.4 and my 2008 expedition?
  #5 (permalink)
Old 09-23-2011, 09:27 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
Scangauge II is a much more versatile tool. Runs about $100-130 new
it will read any OBD-II compliant vehicle. So basically any vehicle from 1996-current. Shows 4 gauges at a time.
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #6 (permalink)
Old 09-25-2011, 11:19 AM
Check the Interceptor (Aeroforce) website. The device is manufacturer and buss specific. This one will work on my '07 Expedition but not '02 Explorer. CAN2 vs CAN data buss. There are specific models for Ford, GM, Chrysler, etc based on the data their systems put on the buss.
This gauge is designed to mount in a pod but I've stopped looking for a nice pillar post pod for my Expedition. Tried one for the F150 and it was unacceptable. I temporarily mounted mine in a corner the dashboard 4 years ago. Still Velcroed there.
The gauge will cycle thru four parameters on both displays for a total of 8 displayed (2 at a time). There is also an alarm that can highlight any parameter. Mine alarms Transmission Temperature. They guys with Mustangs use it as a shift indicator. I typically monitor transmission temperature (trailer towing) and cylinder head temperature. Engine coolant temperature runs flat line just below 200°F with my trailer.
More of a gadget with my 5000 pound camper and 9000 pound maximum towing capacity. If you're towing closer to maximum transmission temperature is a critical thing to monitor.
Note the Green display is blinding at night and inconvenient to dim via the menu. At least on my early model. The Areoforce guys used my Expedition to find Transmission Slip (Trans Slip 2). They reflashed the firmware and replaced my display with Red which is wonderful at night but nearly invisible in daylight. Maybe blue is a good compromise?
-- Chuck
Tags
2005, expedition, obdii, temperature, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
