NO Limit Fab?? - Ford Truck Enthusiasts Forums
NO Limit Fab??
Old 09-23-2011, 10:55 AM
F1Newb F1Newb is offline
F1Newb is starting off with a positive reputation.
NO Limit Fab??
Okay I've searched and only found a few threads here and on the net that gives some decent install pic's of the suspension, although most of them are rear shots but I have additional questions that I can not seam to find.
Does any have a running and driving truck with this on?
I also would like to see how low it sits with the truck atleast driveable.
Lastly I noticed the rear shock mounts outside the frame rail which looks like it takes away some tire width. So how wide of a tire can be put in there?
I'm really not concerened about fitting a big tire at the moment but you never know what the future holds.
Thanks guys
Chuck D
Old 09-23-2011, 11:48 AM
9teen56f100's Avatar
9teen56f100 9teen56f100 is offline
9teen56f100 is gaining momentum as a positive member of FTE.
Rob (owner of No-Limit) is a member here. He stops by from time to time. Maybe he will respond to your questions. You could PM him. (DROPTOP46) He really builds some nice stuff.
brian...
Old 09-23-2011, 11:58 AM
Here is one he built for the 2006 F-100 Supernationals give-away.
brian...
<a href="http://s619.photobucket.com/albums/tt278/9teen56f100/other%20trucks/?action=view&amp;current=NOLIMIT56giveawaytruck.jp g" target="_blank"><img src="http://i619.photobucket.com/albums/tt278/9teen56f100/other%20trucks/NOLIMIT56giveawaytruck.jpg" border="0" alt="Photobucket"></a>
Old 09-23-2011, 12:11 PM
Yeah he seams busy because I have not heard back from him yet.. I'll keep looking for pic's
Thanks for your help
He does know his stuff
Old 09-23-2011, 01:56 PM
tacson's Avatar
tacson tacson is offline
tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.tacson has a very good reputation on FTE.
Chuck D,
Here is one in the build stage. I dont think it is on the road yet
http://www.ford-trucks.com/forums/10...o-proud-4.html
Old 09-23-2011, 03:44 PM
Perfect thanks....
tires and wheels Leef250 1973 - 1979 F-100 & Larger F-Series Trucks 0 11-10-2016 07:07 PM
How wide of tires can I go?? MartyTheOneManParty 1967 - 1972 F-100 & Larger F-Series Trucks 20 07-28-2016 12:31 AM
Looking for the truth on "dry rot..." Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 25 10-11-2015 02:30 AM
Mixing tires on a Dually jonrjen 6.7L Power Stroke Diesel 23 09-29-2015 06:50 PM
Removing tire studs and how good is tire afterward? Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-10-2015 01:16 AM
Tags
1955, 64, chassis, f100, fab, fabrication, ford, limit, limits, limmit, nolimitt, ride, suspension, track, wide, width
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
