Limited Slip Additive - Ford Truck Enthusiasts Forums
Old 04-06-2003, 09:50 PM
AggiePSD's Avatar
AggiePSD AggiePSD is offline
AggiePSD is starting off with a positive reputation.
I was going through all of the fluids on my truck the other day and when I was picking up oil for the rearend, I bought a tube of K&W additive for the oil. It was called posi-trac additive or something. Well after I was through I got to looking at the book and it called for 8 oz. and my tube was only 7 oz. Is that enough to make a difference? And is there a difference between the additives for Fords and Chevys? Because I have been noticing this slight vibration only when turning at idling speed. It seems to do it more in reverse but it did it in forward today. I thought it was something up front, but I'm beginning to think it's from the rear. So did I get the right oil additive and the right (or close enough) amount?
Thanks,
Old 04-06-2003, 10:28 PM
medic641 medic641 is offline
medic641 is starting off with a positive reputation.
For limited slip differentials, it's usually recommended to drive the vehicle in several tight figure of 8 patterns after changing the lube to get the new stuff worked in.
If it continues to chatter after that, then I'd say you would need additional external friction modifier added. Just enough though, too much will render the limited slip useless, or ineffective.
Most synthetic gear lubes on the market now, already contain the friction modifiers in their formulation. This is one area where I feel synthetics are of benefit, compared to the crankcase.
Old 04-07-2003, 01:50 AM
bronco351 bronco351 is offline
bronco351 is starting off with a positive reputation.
Also, some of the conventional gear oils have the friction modifier in them already!!!
Old 04-07-2003, 09:02 AM
MrBSS MrBSS is offline
MrBSS is starting off with a positive reputation.
If a differential gear oil says it is "for" limited slip differentials, does that mean it already has the additive, or just that it is compatible with limited slip differentials?
Old 04-07-2003, 10:43 AM
jim henderson jim henderson is offline
jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.jim henderson has a great reputation on FTE.
I have a 94 F250 heavy duty 460 E4OD 4WD etc. My manual calls out for 16oz of additive if I recall. I always add 2 8oz tubes of Sat Lubes version of this additive. The tube says it meets spec for the Ford and Chevy Specification(called out by number on the tube).
On another website I visit, there is a lot of discussion about how much additive to add. In general #1, follow the manual recommendation; 2) If using synthetic, we usually get better results with 2 tubes; 3) If it still chatters add a bit more additive; 4) Do some figure 8s to spread it around.
I read that GM and Ford differentails work in differnt ways and the additive modifies the friction up on one and down on the other, strange.
Good Luck,
Jim Henderson
Old 04-07-2003, 02:47 PM
Correct, if the back of the bottle says it's for limited slip differentials that means it has teh additive in it!!
Old 04-07-2003, 04:05 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
The shop that rebiuilt my 8.8 prefers the GM additive. Mine works great without chatter on the GM stuff. They can't be that much different because Dana axles are used in all makes and they don't specify a different additive for Dana axles.
Jim
Old 04-07-2003, 04:21 PM
With all due respect, are you sure?
Maybe I've been wasting money by using the additive, however, to my recollection, my manuals have always specified that an additive be added to the specified gear lube when used in a limited slip unit. Never has this been qualified in any way (such as: "unless already present").
Also, my bottle of Valvoline Durablend (synthetic blend) gear oil says it is for "all hypoid differentials (conventional and limited slip) and..." If limited slip requires different frictional characteristics, could it work for both without an additive? Or maybe the additive is necessary for LS, but doesn't hurt in an open diff?
Also, I'm interested in the idea that too much additive could prevent the limited slip from functioning as such. Do I properly infer then that we should use as little as possible unless chattering occurs?
Old 04-07-2003, 04:57 PM
AggiePSD's Avatar
I really thought that my book specified only 8 oz. but I could be wrong. I need to check that because it could be the problem. I used K&W, so I dont even know if it is for GM or Ford or both. Threw away the tube. I think my Valvoline oil said the same thing: for conventional and limited slip axles. I'll have to check around on this one I guess.
Thanks,
Edit: The only thing I can find is that they recommend 8 oz. friction modifier. And the oil does say it is for all hypoid applications (conventional or limited slip). Now I just need to find exactly what that K&W stuff is made for.
Old 04-07-2003, 05:07 PM
The amount of friction modifier needed I believe is related to how worn the clutch packs are on LSDs. It seems, the more wear, the more modifier is needed. Some have reported having to add friction modifier to synthetic lubes, that already contained the additives, to stop chatter.
I'd add the modifier by trial, a few ounces at a time until chatter is gone.
You'll know if there's too much. It'll act like an open differential on slippery surfaces.
Old 04-07-2003, 05:40 PM
Well, that doesn't seem right. If the additive makes the clutches less "grabby" would you need more of it as they wear? I would think that they'd slip more as they wear out, but I must admit, I don't really know!
Old 04-07-2003, 06:19 PM
[QUOTE]Originally posted by medic641
[B] It seems, the more wear, the more modifier is needed.
Yes, I'm wrong here. It should be the more wear, LESS modifier is needed.
Friction modifiers will eliminate noise, but can sacrifice performance.
Old 04-07-2003, 06:35 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Quote:
Originally posted by MrBSS
...........my bottle of Valvoline Durablend (synthetic blend) gear oil says it is for "all hypoid differentials (conventional and limited slip) and..."
I use the same stuff in my front diff and also my 3.73 LS rearend. I had to add about 2-3 ounces more of the friction modifier to stop some chattering I had going around corners. Leads me to believe that if there is an additive already in there, it's probably not a real heavy dose.
00 f250 superduty 5.4l pag oil ac system capacity when changing compoennts pzp107 1999 to 2016 Super Duty 3 07-25-2016 12:56 PM
Diesel Fuel Gel test - Pwr Srvc, Howe's, Schaeffer white Buffalo 1999 - 2003 7.3L Power Stroke Diesel 90 10-27-2015 04:01 PM
97 Explorer A/C Accumlator Oil Capacity GTEK Cooling, Heating, Ventilation & A/C 12 06-24-2010 10:54 PM
Fuel additives FORD MEGA CAB!!! Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 08-17-2008 03:21 AM
Good bottle for Diesel Fuel Additives??? Twin Tritons 6.0L Power Stroke Diesel 23 11-25-2004 11:36 AM
Tags
add, additive, chatter, difirental, f150, ford, friction, kw, limited, modifier, much, posi, slip, too, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
