Did you offset your engine for a Volare clip? - Ford Truck Enthusiasts Forums
Old 09-23-2011, 07:37 AM
raerjim's Avatar
raerjim raerjim is offline
raerjim is gaining momentum as a positive member of FTE.
Went to bolt my bare block back up in the mounts and to tranny so I can get some measurments to remove cobbled, PO fabbed motor mounts and weld in new MF offset pre fabbed mounts. (some assembly required) I replaced the crossmember trans mount with the only mount I could find that is close, but not exact replacement. It is about 1/2" taller, which is going to change my pinion angle. That and the fact that when I got everything in and bolted up, the angle now on the tranny puts the mount in quite a bind. I don't care for that. It will surely twist the rubber out of the mount in time. I have an aftermkt. trans crossmember. Did you have to relocate your trans mount holes on the X-member to relieve the tension?
Old 09-23-2011, 08:50 AM
gdub's Avatar
gdub gdub is offline
gdub has a very good reputation on FTE.gdub has a very good reputation on FTE.gdub has a very good reputation on FTE.
I offset the engine and transmission about an inch to the passenger side. I built my own crossmember and offset the holes on it too.
Old 09-23-2011, 10:42 AM
jniolon's Avatar
jniolon jniolon is offline
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
+1 on offset... mine was 2" and fabbed my own trans mount
BUILDING A NEW TRANSMISSION
john
Driveshaft angles Piston Honda 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-01-2014 02:52 PM
4.6/Crown Vic install question Jim 54 panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-28-2013 02:57 PM
Im back!!! Putting the 351c/c6 into the truck!!!Need help with the trans mount. rtcalabrojr 1948 - 1956 F1, F100 & Larger F-Series Trucks 38 02-14-2010 03:26 PM
Transmission mount/crossmember 89Bulldog Ranger & B-Series 1 01-08-2010 09:53 AM
4.6L swap into 89 f150 (F-STANG project) trk98 1987 - 1996 F150 & Larger F-Series Trucks 67 06-26-2009 01:54 PM
Tags
100, 1963, clip, crossmember, engine, f100, ford, motor, mount, offset, offsets, truck, volare
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
