How do you get a window motor out of f150 - Ford Truck Enthusiasts Forums
Old 04-06-2003, 10:35 PM
fishnxtc fishnxtc is offline
fishnxtc is starting off with a positive reputation.
Angry How do you get a window motor out of f150
I have a 2001 F150 and I think the window motor is bad. I took the door skin off and tried to get the motor out. Well ford though it would be cool if they pop-rivited the peice the motor is connect to. So I need some advice on the best way to get the motor out to check it............Chris
I really need some help?????????????
Old 04-06-2003, 10:48 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Ford has been doing that since, uh. forever Well at least 20 years.
Drill them out and replace with bolts and nuts.
Old 04-06-2003, 11:06 PM
That is what I was think of doing. I wasn't sure if that was wise or not. Can I post a trouble shooting problem to you?Thanks so much for the reply.........Chris
Old 04-07-2003, 12:54 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
This is what the manual says. You dont have to remove the window regulator which is held on by the rivets.
Raise the front door window glass to the full up position.
Remove the front door trim panel.
Position the watershield aside.
CAUTION: Make sure the electrical connector is positioned aside before drilling.
To access the power window motor bolts, use a 19 mm (3/4-in) hole saw with a 8 mm (1/4-in) pilot to drill three holes at the existing drill dimples on the door.
Disconnect the front door window regulator electrical connector.
Remove the bolts and the front door window regulator motor.
To install, reverse the removal procedure.
Cycle the window glass to make sure the gears engage.
Old 04-08-2003, 08:18 PM
Buck000 Buck000 is offline
Buck000 is starting off with a positive reputation.
I was wondering how do you remove the door panels? I am going to replace the speakers in my 99 f150 excab.
Thanks,
Buck000
Old 04-08-2003, 08:53 PM
Racerguy's Avatar
Disconnect the battery ground cable.
Remove the front door trim moulding. (vertical piece at back of door..it just pulls off)
Remove the inside door handle finish panel. (again it just pulls off...there is a little notch to put a screwdriver in to carefully pry it off)
If equipped, remove the window regulator switch plate (just pulls off too)..........
Lift the front of the window regulator switch plate.
Disconnect the electrical connectors.
If equipped, remove the window regulator handle (23342)......
Separate the handle cover from the handle.
Remove the screw.
Remove the window regulator handle.
Remove the spacer.
CAUTION: Do not pull directly outward on the front door trim panel, as damage may occur.
Remove the screws. (one at back top of the panel and one in behind the door handle)
Lift and remove the front door trim panel.
If equipped, twist the courtesy lamp bulb socket one quarter turn and remove the socket from the front door trim panel.
Old 04-08-2003, 09:03 PM
Thanks Racerguy, you saved me from some damage. I figured that they would pull right off like my 89 f150, but they pull up instead.
Thanks,
Buck000
Old 04-08-2003, 09:14 PM
Racerguy's Avatar
I've seen a few panels broken because people assumed they pulled straight off. Good old Ford likes to keep us on our toes with things like that.
Old 04-08-2003, 10:46 PM
03f150man 03f150man is offline
03f150man is starting off with a positive reputation.
racerguy, in particular your posts are really helpful and obviously come from someone who knows what they are doing. (thinking now of the postings about emissions controls, engine driveability problems, what buck000 mentions,etc). thanks for the help.
Old 04-08-2003, 11:57 PM
Racerguy's Avatar
Thanks for the kind words
I work on these things for a living so I do have to hopefully have some idea what I'm doing.
I've learned things from other people on here too though
It's great seeing different opinions and insights into how to fix things. We have some pretty brilliant people on here.
Old 04-09-2003, 12:25 AM
Hey thanks a lot. I looked at the dimples and there are only two but it looks like it will work out. If you ever need some help salmon or sturgeon fishing let me know or check out this site www.ifish.net ..............chris
Old 04-09-2003, 12:50 AM
Racerguy's Avatar
I'm up in BC, near Alaska and we probably have as good fishing as you do there
Ok,ok, we dont have sturgeons here but we do have lots of salmon.
Now if only we could keep the Americans from catching all of ours
I guess we shouldn't go there eh?
hehe
Window motors fordka 1987 - 1996 F150 & Larger F-Series Trucks 0 06-22-2014 05:57 PM
1998 F150 Power Window Problem cstrack 1997 - 2003 F150 35 06-26-2008 05:18 PM
2001 F150 Fuse Diagram tanksgt 1997 - 2003 F150 1 03-15-2008 08:40 PM
Funkiness with door window motor - 97 f150 XLT cfauvel 1997 - 2003 F150 3 08-03-2005 08:59 AM
power window motor 79bobcat81 1987 - 1996 F150 & Larger F-Series Trucks 13 07-28-2003 02:49 PM
Tags
2001, f150, motor, remove, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
