Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-22-2011, 11:11 PM
66LTD 66LTD is offline
Garage is empty, add now
66LTD is starting off with a positive reputation.
Question help help help!!!!!!!!!!!!
i have a 1966 Ford Galaxy LTD with a 352 FE. MSD distributor, coil, wires and 6AL ignition control. edelbrock performer 390 intake manifold. edelbrock victor series water pump. Holley mechanical fuel pump 110gph. Holley Double Pumper, not sure what size but the primary jet size is 67H and secondary jets 73H. Ford Powertrain custom shorty headers (2 1/2 outlet) with flowtech purple hornies header muffler 3" in and out. Im having some timing and carb problems. #1- What is the best timing degrees, and how do i adjust the air/fuel screws on my carb? #2- how do i found out the size of my carb? #3-does anyone see any other problems with my motor set up. Thanks for the help guys its much appreciated!!!
  #2 (permalink)
Old 09-23-2011, 04:48 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
jowilker jowilker
IMHO, The engine can't use the fuel that is delivered unless you are using it for straight line driving only.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #3 (permalink)
Old 09-23-2011, 03:13 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Is this all piled on top of an otherwise stock (and worn out?) 352?
A double pumper carb isn't meant for this application.
QUESTION How do I know if a vacuum or mechanical carburetor is best for me?
ANSWER For street cars the vacuum secondary carburetor works best on midweight or heavyweight cars with an automatic transmission. They are more forgiving than a Double Pumper is because they work by sensing engine load. The mechanical secondary carburetor is best on a lighter car with radical camshaft and a lower gear and manual transmission or on a car that is going to be used for racing purposes
This from the Holley site FAQ's, which also covers carb ID:
Holley Performance Products Frequently Asked Questions
You are dumping more fuel into it than it can use. Your carb may also be way oversized.
If you have a stock cam, your 352 will probably never be north of 5000 rpm, maybe not even 4500. A 600 cfm carb is plenty for that motor.
As for idle screw adjustment, turn them in, then out 1 1/2 turns. Adjust for best idle, then turn them 1/4 turn in.
Timing: factory might have 6 degrees for a 2bbl regular fuel motor, about 9 or 9.5 compression, or 12 degrees for a 4bbl premium fuel motor, 10-10.1 compression. Start at 6 and go as far as you can without pinging--probably around 8 or 10.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
