Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-22-2011, 09:06 PM
actor76 actor76 is offline
Garage is empty, add now
actor76 is starting off with a positive reputation.
'08 Expedition auto power window
I had to replace the window regulator in my driver's door.
Everything went will, did the whole thing in a little over an hour.
The problem I have is that the Auto up stops about an inch short of closed. I can close it the rest of the way by holding the up button. Auto down works fine. Goes to the bottom and stops.
Is there a way to reset the Auto function so the window closes all the way?
Thanks for the help.
  #2 (permalink)
Old 09-23-2011, 01:02 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Hmm. Is it binding at all?
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 09-23-2011, 01:07 PM
berry1234's Avatar
I am not sure there is a calibration for the newer trucks, there was for the older mustangs and F-150s. Maybe google that.
__________________
  #4 (permalink)
Old 09-23-2011, 01:27 PM
Thanks for the replies.
It's not binding at all. Window goes up and down fine.
It's just the auto function that doesn't work correctly.
I did google it and found one link that tells you to hit a button up and down sequence with the ignition on and off but that didn't work.
Tags
07, 2007, 2008, auto, detail, expedition, ford, function, lincoln, navigator, power, reinitialize, reset, resetting, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
